smartSDR 1.4.16 crashes on 15 meters. It was working OK before until...
DaveC
Radio: Flex-6300
software: 1.4.16
Direct connection via NIC to computer
The radio was working fine. I had just selected 15 meter. I was adjust things and it suddenly stop working, by that I mean no audio output, there was data on the spectrum scope but nothing on the waterfall, and I lost complete control and then smartSDR crashed.
It displayed the "Connection Lost" popup box with the message "the connection to the radio was lost. Please reconnect". I click the OK button and the radio setup window appeared. It showed that my radio was already in use. So I could not reconnect. I also looked at the activity Ethernet LEDs on the computer and they flashing normal.
I power cycled the radio and also rebooted my computer. I reconnected to the radio and it works fine on all bands but 15 meters. Whenever I switch to 15 meters, smartSDR crashes in the way described above.
software: 1.4.16
Is it crashing during transmit? If so I would suggest you have RF getting into the radio or RF getting into the network cable causing it to loose connection.0
No, not during transmit. in receive mode. Like I said up until tonight it was all good.0
I'm running 1.4.16.63 with no issues at all.0
Dave,
I have converted this topic to a support HelpDesk ticket (http://helpdesk.flexradio.com) for expedited issue resolution. Please export your profiles and attach it to the ticket e-mail you will be receiving shortly. I believe there is something amiss in your profile that is causing a problem and I want to capture that data before we try to resolve it.
If anyone else is experiencing an issue similar to this one, please submit a HelpDesk support ticket for issue resolution.0
- 694 The Flea Market
- 357 FLEX-8000 Signature Series
