Adjustable clock/date display
I would prefer a user-choosable format of the clock/date display. Just a small issue but look how it looks, sittig right over the Windows-Clock.
It would be great to choose if UTC or another timezone is displayed, and how the date is formatted (dd/mm/yy, dd/mm/yyyy, mm/dd/yyyy, mm/dd/yy e.g.). Also it would be nice to show it aligned to the Windows date/time-format. In my case time above date.
VY73
Tom
DK1EY
VY73
Tom
DK1EY
10
Good idea1
If you think so, please press the like button above to vote for that idea!
Many thanks es
VY73
Tom
DK1EY1 -
Yes, a good idea.
We already get digital clocks on phone, coffee brewers, stoves, microwave ovens, Windows desktop. Do we really need another local time digital clock? UTC time, yes, local time no2
I would prefer that SmartSDR display both local and UTC, and not depend on placing SmartSDR over the task bar (as I use a multi screen configuration with self-hiding task bars).
Steve
K9ZW
Walt and Steve, Due to different needs, I would appreciate a flexible solution. I also prefer and only need the UTC clock in the SSDR window. VY73 Tom DK1EY0
Next these guys will want it on the screen for the Radio Box when does it end. I have local, GMT etc on various programs buy a second monitor and get what you want it's just a radio Tom. Ian0
How about leaving the display as is, in UTC, but if mouse-overed adds an offset and displays local time. Much like how the S-meter implementation behaves. Or ... look at the clock on the wall.
W7NGA
Koh Samui, Thailand0 -
Surely you can add or deduct a few hours from UTC. Do these trivial wants never end!!!!! Surely Flex has enough to do with basic additions/upgrades to SmartSDR.
Jim K4JAF
Move to Greenwich? They are both the same!0
The current SSDR clock is really tiny and hard to read on a big display. I would like selectable size, time zone, and format, and yes, maybe color! Compared to SDR, this is not rocket science. The bigger issue for FRS is probably finding screen space for it in their rigid windowing system. Ideally we'd have a separate window (maybe a tear-off window) with the clock as big as you want and located where you want on your monitor.
In my case, it's a little redundant, since I run the following Python code on my system.
Flex is welcome to copy!
Sounds like you have your problem solved!!! I prefer Flex to spend their time on improving the operation of the 6000 series, not adding UTC and Local time to the screen.0
- 688 The Flea Market
- 105 Aurora
- 974 Genius Products
