CWX CharSent Event Timing Question
K9DUR
Does the CharSent event fire when CWX starts sending a character or when it finishes?
It appears to fire when the character starts sending. I need to be able to determine when a character has finished sending.
73, Ray, K9DUR
The OnCharSent event is triggered by a status message from the radio saying it was sent. My guess is, it means the character has left the building. Otherwise it should be charAck that the radio received it from the user.
It's probably pretty easy to test, if you can trap the event, better yet, breakpoint the event sink, and see if the transmit light has come on and gone off before the breakpoint is hit or, what I suspect is unlikely, hasn't come on at all yet.
Doesn't CWX strikeout the character as it is sent. Yeah, I give the odds 99% it left the building. But you'd have to talk to someone familiar with the radio programming to be 100% certain.
I had just gotten home from the gym. In the shower a better way came to me.
15:42:31.024 [pool-2-thread-3] - sending cmd C24|cwx send "kz1f"
15:42:31.368 [pool-2-thread-3] - received reply R24|0|8
15:42:31.369 [pool-2-thread-3] - received status S0|interlock state=PTT_REQUESTED
15:42:31.369 [pool-2-thread-3] - received status S0|interlock state=TRANSMITTING reason= source=SW
15:42:31.969 [pool-2-thread-3] - received status S0|cwx sent=80 -
Forget this whole thread. It does indeed fire after the character has been completely sent.
I found a bug elsewhere in my code that was making it look like it was firing prematurely.
73, Ray, K9DUR
FWIW, Ray, that was kind of a fun exercise. But what's amazing, and somewhat to your point as far as timing, notice the times from initially sending the request.
350ms from request to radio acknowledgement of the request
1ms for the radio to initiate the transmission, note requesting ptt.
<1ms to transition to transmit mode
300ms to get acknowledgement processed of the first character sent.
So, yes, on the event sink, the character has, in fact, left the building.
You could request, as it is your thread, that Tim mark it answered.
- 692 The Flea Market
