flex 3000 PA
Keith Morrison
Keith Morrison Member ✭✭
edited February 2018 in FLEX Series (Legacy) Radios
Hi all finally got my Flex-3000 up and running on DM-780, I only intend to use my radio for digital modes RTTY, PSK-31 and the likes.
Just wondering if the PA in these radio's are good enough to transmit full duty cycles for long periods, not constant but you know what I mean send a macro and then wait for a reply and so on.
I run a max of 30-40 watts in the digital modes.
any info would be good thanks
Keith M1VHT
  • Bill -VA3WTB
    Bill -VA3WTB Member ✭✭✭
    It is fine to run full duty at a 100W, The fan will speed up as it needs to. The amp is protected from over temp anyway. Have fun, that's a great radio.
  • Keith Morrison
    edited July 2017
    Excellent to hear thank you for your reply.
    73 Keith
    edited March 2017
    As per the FLEX-3000 specifications, the PA in the FLEX-3000 is a 100w nominal class AB full duty cycle RF power amp operating on the 160-6m ham bands. Operating full duty cycle high power digital modes, like RTTY should present no problem with the FLEX-3000.  The fans will ramp up to cool the PA heat sink as necessary.
  • Keith Morrison
    edited July 2017
    Thank you
    73 Keith
