DAX UI anomaly
DrTeeth
DrTeeth Member ✭✭
edited December 2019 in New Ideas
The usual action that occurs when clicking or double-clicking on an icon in the status tray is that the main window if the application opens. If the main windows does not (that is very rare) at least something does.
No so with DAX. All that happens is that an icon appears in the task bar - no window opens and I feel that it should.
Using Win 7 x64 and SSDR 1.3.8.
1 votes
In Review · Last Updated
  • James Whiteway
    edited December 2018
    I just tried it on my Win Vista machine, DAX control panel popped right up. Not sure why it would not work for you. I don't have SSDR installed on my Win7 setup, so I cannot test it there.
    Good luck.
    james
  • Steve W6SDM
    Steve W6SDM Member ✭✭✭
    Guy, it does the same thing with me.  Running Win7 ultimate.
  • RoyS
    RoyS Member ✭✭
    Guy,
    I'm running win 7 Home Premium (Win 32/64) -- SSDR 1.3.8
    When SSdr boots up, I get a small icon in the tray on the bottom far right. Right clicking on the small icon brings a small text box with the following: Show Control Panel and Exit. Left clicking on Show Control Panel brings up the Dax Panel and a larger icon in the left portion of the tray. If I minimize the panel and then left click the large icon, the panel reappears. If I close the panel, it goes away and the large icon goes away also. I have to go back to the small icon to get the panel back. hope this helps.
    Roy
  • DrTeeth
    DrTeeth Member ✭✭
    edited August 2016
    Vista and 7 are very different beasts. I run both.
    Thanks for your input and have a nice weekend.
  • DrTeeth
    DrTeeth Member ✭✭
    edited August 2016
    Hi Roy,
    I know all that you said, but normal windows convention is that a window opens when an icon is double-clicked in the status tray. DAX is the only program that does something as useless as place an icon in the taskbar ;-).
  • DrTeeth
    DrTeeth Member ✭✭
    edited August 2016
    Phew, nice to know it is not just me, hi hi.
  • RoyS
    RoyS Member ✭✭
    edited December 2016
    Understood Guy. Have a great weekend.
    Roy
  • KY6LA_Howard
    KY6LA_Howard Member ✭✭✭
    edited January 2017
    Guy Thanks for posting my primary **** with DAX Tiny Uselss Icon in Notification panel that requires RIGHT CLICK to activate control panel Almost impossible to activate remoting
