CWX - Message auto-repeat function request
IW7DMH, Enzo
Hello,
as I am mostly a CW operator I would like to have, in next SSDR releases, an "auto-repeat" message function in CWX.
I am finding it a bit annoying having to click every time F1 to repeat my call message.
It also might be useful defining a meta-language to be used in the hot key messages (something like {WAIT 5} just as an example).
Thank you very much
73' Enzo
iw7dmh
Thank you very much
73' Enzo
iw7dmh
4
good idea, Enzo....73, w5xz, dan
Hi Enzo,
Here is a workaround you can try.....
Setup up the memory with your call repeated several times separated by about 25 spaces.
- 25 spaces gives about 3-4 seconds between calls at 22 WPM
- in the example press F1 to start sending your call
- press ESC to stop
- you still can listen between calls
- it won't repeat forever but that may be a good thing
Regards, Al / NN4ZZ
al (at) nn4zz (dot) com
3 -
Thank you vey much dear Al,
it works perfectly!
At the beginning I was a bit hesitant, but my 6300 is proving to be a real astonishing cw machine.
Hope to see you on air.
73' Enzo
iw7dmh
Al, what I'd like is the ability to go into 'beacon mode' on a dead or just opening band; send
"CQ CQ CQ DX de W5XZ W5XZ W5XZ DX K" then pause 15 - 30 seconds, and repeat...
Trolling we call it on top band, i think....73, w5xz, dan
Dan,
Yes, a "delay and auto- repeat" feature would be a better solution for what you want.
There could be some issues unless the repeat command had a limit on the maximum number of repeats.
There is another option --- You could use a "keyboard simulator." But unless you do this a lot it may be more trouble than its worth. Here is one example that has the delay and repeat feature and it is free.
http://www.softpedia.com/get/System/System-Miscellaneous/Keyboard-Mouse-Simulator.shtml
After you set it up, use CWX in the LIVE mode. Might be fun to try.....
Regards, Al / NN4ZZ
- 419 Community Topics
- 718 The Flea Market
- 226 SmartSDR+
- 472 SmartSDR for Mac
- 282 SmartSDR for iOS
- 270 SmartSDR CAT
- 225 DAX
- 397 SmartSDR API
- 143 Aurora
- 389 FLEX-8000 Signature Series
- 1K Genius Products
- 366 Tuner Genius XL
- 139 Antenna Genius
- 334 Shack Infrastructure
- 237 Networking
- 150 Contesting
- 149 Amateur Radio Interests
