diversity receive, can and how do we use a rx only antenna
    Tim - W4TME admin
    edited March 2017
    By its very definition, you need two fully independent RF signal paths to do any type of diversity reception techniques, so if you only have a single antenna, diversity reception is not possible.
  • Al_NN4ZZ
    Al_NN4ZZ ✭✭✭
    edited October 2017
    John
    Here is an example of diversity on my 6700 with a yagi and a receive only antenna.
    - Slice A is using ANT 1 which is a 2el yagi for 40M.  This is the transmit antenna.  (see second picture below)
    - When I clicked DIV on the DSP tab to activate diversity,  slice B was automatically created and slaved to Slice A.  (see second picture below)
    - Slice B is set up to use RX B for the antenna which is my K9AY loop (a  receive only antenna).  You can click on the RX B tag to select a different antenna if you wish.
    If you look at the audio TAB in the picture below,  you will see:
    - Slice A is automatically set for the LEFT channel
    - Slice B is automatically set for the RIGHT channel
    - Note: if you disable DIV Slice B will be deleted automatically and the audio slider for Slice A will be returned to the center setting.
    I hope this is helpful.....
    Regards, Al / NN4ZZ
    al (at) nn4zz (dot) com
  • John Molenda
    edited December 2014
    Thanks Al and Tim , I am just reading your answers today Yeah a little busy .  John kb2huk
