Flex 6300 not able to get two panadapters with 2 differente antennas
William Schauff
William Schauff Member ✭✭
Hi All!
Using Flex6300 on Windows 7. If I use two panadapters, cannot use 2 different RX antenas. If I change  the RX antenna in one of the panadapter, the other change also for the same antenna making impossible to get two different antennas working at the same time.
I kindly ask for help.
William PY2GN
  • GI4FZD
    GI4FZD Member
    edited April 2017
    There is only one receiver in the 6300 so no matter how many slices you are using they all are part of that single receiver. You need the 6700 to have different antennas on 2 different bands or slices or to use diversity reception. Cheers Paul
  • Nick - W2NER
    Nick - W2NER Member
    edited January 2017
    Or the 6500...
  • William Schauff
    edited January 2019
    Hi Friends|!
    Thank U so much for the fast reply!
    Need to plan next aquisition....hihi
    William Py2gn
  • KY6LA_Howard
    KY6LA_Howard Member ✭✭✭
    edited January 2017
    Wrong. The 6500 only has One Spectral Capture Unit. You need a 6700 for 2
  • KY6LA_Howard
    edited July 2016
    Wrong. See below
  • Nick - W2NER
    Nick - W2NER Member
    edited February 2015
    I stand corrected, I was thinking about the TX pull down to select an antenna.  Getting old...
  • Stan VA7NF
    Stan VA7NF Member ✭✭✭
    It is possible, on a limited scale, to place a diplexer/triplexer on your antenna feed that will make several antennae APPEAR as one antenna to the 6300.
    You will still be limited to a single TX antenna, or turn off the ATU, or retune on every TX band change.
    The RX will be in WIDE mode.
    Even the 6700 comes up short with a TX antenna on ANT1, diversity RX antenna on RX2, and 2M amp on XVTR.  The diversity antenna can be diplexed (can diplexer be made a verb?) with the 2M signal on the XVTR port.
    Stan
  • Ken - NM9P
    Ken - NM9P Member ✭✭✭
    edited December 2016
    I have done similar with a 6 meter diplexer and antenna on my 6500. It worked, But performance suffered a little when SWR was high on the HF side antenna. The biggest problem was that the preamp setting was the same for all bands. With the preamp turned ON for 6 meters, it made 40 and 80 really noisy.
  • GI4FZD
    GI4FZD Member
    This is a good reason to use something like a six band hexbeam or cobweb as one of your antennas, having 6 resonant bands on one coaxial feed to the radio is very handy.
    cheers
    Paul
  • Ken - NM9P
    My T-11 log periodic goes up in late October! I can hardly wait! 20-6 on one feed Line!
  • William Schauff
    edited September 2014
    This will be great!
  • GI4FZD
    GI4FZD Member
    edited June 2016
    Very nice.
    Wish I had the room here.
    Cheers
    Paul
