6500 and palstar AT-AUTO
jim
jim Member ✭✭
i want to connect my 6500 to AT-AUTO   using my COM PORT
will I need  serial interface    between the computer and the tuner?
trying to use DDUtil    config com #1    in repeater 1
9600 baud  (as in at-auto) and ck palstar
but do i need a interface in the rs232 line
flex 6500   1.3 software
windows 7  on i7 machine
latest  DDUtil 3.0.9
i have nothing else  running with DDUtil
the only other  i have in  ddutil   is  :
features, radio slect   checked signature  and  port com7
from  smart cat  com7-17 (shared)
  • Mack
    Mack Member ✭✭✭
    edited March 2019
    Yes, you will need a physical com port from the computer to the Palstar. Ddutil has detailed setup instructions online. Just read the Ddutil manual.
  • David Decoons, wo2x
    Just a straight through db9 male to female cable from PC physical CPN port to AT-Auto. Make sure reset jumper in tuner is removed. Dave wo2x
  • jim
    jim Member ✭✭
    edited February 2020
    thanks  MACK  and DAVID
    i just can't get it  work  correct .
    it most likely  is the operator ...
    at 74 hope i live long   :)   hi hi
