6300 no longer keys amp
Burch - K4QXX
Burch - K4QXX Member ✭✭
edited October 2019 in FLEX-6000 Signature Series
My 6300 has been working great.  Last night I was trying to work some DX and my 6300 wasn't keying my amp.  I have a Ameritron ARB-704 keying buffer between my radio and amp and I notice the red XMT light was not coming on when I keyed the radio.  My 6300 has always keyed the amp when the radio was turned on but before I launched the SSDR software.  Once the software was loaded, the radio un-keyed and worked as expected.  The radio still keys up the amp when I turn on the radio but don't have SSDR running but no longer keys the amp when I transmit.  Any ideas?
Burch
K4QXX
  • np2g
    np2g Member ✭✭
    edited November 2015
    Your tx has not been selected on your slice.
  • Steve N4LQ
    Steve N4LQ Member ✭✭
    edited September 2015
    Check "Settings" and be sure RCA TX1 is enabled.
  • Steve N4LQ
    So what did you find Burch?
  • Burch - K4QXX
    edited July 2018
    I'm still at work so I haven't tried anything yet.  I might not be able to work on it until tomorrow.
  • Burch Akin
    Burch Akin Member ✭✭
    edited July 2014
    That is what the problem was. I enabled RCA TX1 and I am back in business. What is weird is that I was tuning my amp when all of a sudden the amp quit keying. I wonder how that option got disabled?
  • Howard -W6HDG
    Howard -W6HDG Member
    Burch, just as an aside, the amp keying issue in the 6300 (before starting SSDR) was determined to be a bug and is being fixed in 1.3 from what I understand. Flex did a good job of tracking that one down....
    edited March 2017
    I have converted this topic to a support HelpDesk ticket (http://helpdesk.flexradio.com) for expedited issue resolution.  If anyone else is experiencing an issue similar to this one, please submit a HelpDesk support ticket for issue resolution.
  • Joe Veras
    Joe Veras Member ✭✭
    edited October 2019
    Similar problem. 6300 working great and keying amp when needed. All of a sudden, it goes from not keying amp at all to keying the amp QSK fashion (my amp relay is not suitable for that sort of operation. I had it working with enough delay to keep the amp relay from dropping out unless I deliberately paused. Haven't touched or changed a thing.
    This happens with both the internal keyer and CWX . . . and CWX sometimes sends strange sounding code. Other times . . . well . . . maybe that's why my hair is getting so thin. Any resolution from those who had an earlier experience with Keying/Delay?
  • Steve N4LQ
    edited October 2019
    Joe. I assume you have the "delay" slider cranked up on your TX Panel?
  • Joe Veras
    Joe Veras Member ✭✭
    edited April 2016
    Thanks, Steve. Yes, I have the TX panel delay set; I am using 420 which works best with my amp (an  Ameritron ALS-600S). Yesterday's problem disappeared when I turned the rig and amp on this morning and everything is working perfectly. Can't figure what to attribute that to, except maybe the long, overnight power-off. I did not reboot the computer this morning, but did that yesterday while trying to find a solution to the problem. CWX is also working again. I appreciate your help.
