Adjustable horizontal AGC-T bar in Panadapter
The ability to see a visual representation of the AGC-T level within the context of the current noise floor and signal levels, greatly aids in the understanding and adjustment of AGC-T.
I think this would be a great asset to SmartSDR
73, Dale
WA8SRA
Yes, I would LOVE to see that AGC-T display on SSDR one of these days....0
Neat idea, I like it.1
Hi Dale,
Do you have a snapshot of what this looks like?
I added an idea a few weeks ago to put the AGC-T numeric value on the panadapter bar. Maybe a combination of the two would be worth considering. Some like graphical representations and others like numbers, so having both covers all the bases. Here is a link to the idea I referenced:
https://community.flexradio.com/flexradio/topics/add_preamp_and_agc_status_to_the_panadapter_bar
Regards, Al / NN4ZZ
al (at) nn4zz (dot) com
Hi Al,
Here are a couple of screenshots:
From cuSDR64 console:
< http://www.hamsdr.com/personaldirectory.aspx?id=3505 >
From OpenHPSDR PowerSDR mRX PS console:
< http://www.hamsdr.com/personaldirectory.aspx?id=3506 >
73, Dale
WA8SRA
Dale,
I combined both ideas and made a mockup using the SSDR screen. Does this capture it correctly? I also updated the other idea since I don't know of any good way to combine them for the vote total.
Regards, Al / NN4ZZ
CLICK to view full size......
Hi Al,
That looks perfect -- nice work!
73, Dale
WA8SRA
Since the numeric doesn't have any meaning, why not display the signal level (-98dbm rather than 44). This especially makes sense on the flag and side display.1
I really like the concept, but I wonder....If you have multiple slices open on the same pan, with different AGC-T levels, would it start to get really confusing? I often run 2 or 3 slices when DXing and have the AGC-T set more tightly on the "mob" slice as opposed to the DX station's slice because I don't need the extra noise, just an idea of the condition of the DX station's listening frequency band.
Perhaps an alternative could be a change in color on the slice/filter **** that does the same thing? Or some variation on the theme? (A tic mark on the slice, a partial line that crosses the slice/RX filter **** for an inch or so each direction, a tic-mark with a color change below it....)
I am not sure that I would need a line all the way across the screen because the AGC-T only affects what is happening within my RX filter bandwidth.0 -
I like the idea's about lines. I have already asked before the possibility of marker lines for measurements. https://community.flexradio.com/flexradio/topics/marker_lines
Hi Stan,
Maybe show both values. I'm guessing that the number from the slider position could remain constant and the actual signal level could vary based on conditions. The slider number is basically a value of 0 - 100% of the available adjustment. Does that makes sense?
- left of the line in the border show both (44 and -98dbm)
- when hovering on the slider show the slider percentage (44)
So here is another mockup.....
Regards, Al / NN4ZZ
CLICK to see full size....
Ken,
Here is another option.....also posted in the other idea.
Regards, Al / NN4ZZ
Hi All,
Like everyone else, I have been interminably confused by the meaning of the AGC-T slider on PowerSDR. It does function somewhat like an RF Gain control on other radios. Today I sat down and fed my Flex-1500 audio through VAC and into a PC Oscilloscope, and I finally have the facts, at least for the Flex-1500.
First off, when AGC is engaged (i.e. not Fixed) the output is limited to around -3 dBFS. Fixed AGC allows the level to go beyond and into clipping if a strong enough signal is being received.
Secondly, I found the following relation at AGC Slope = 0:
Knee[dBm] = -10 - Preamp - AGCT
So for example, when AGC-T is set to 70, the knee of the gain curve is at -80 dBm when the Preamp gain = 0. For Preamp gain = 10 dB, the knee goes to -90 dBm, and so on.
I haven't checked the Flex-3000 yet, and I don't know about the Signature Series.
- 73 de Dave, N7AIG
The boxes with the AGC numbers could display when you hover on the line and disappear a few seconds later or when you move, just like the filter width display does. Keeps the screen from being too busy.
Or if some folks like the numbers being visible all the time there could be a fade option.
- 1 second
- 5 seconds
- never
We know the developers like providing options....;-)
Regards, Al / NN4ZZ
I have added this to the feature request list.2
Upvoted and would love to see this in SDR4.
I have this feature on my Hermes Lite 2+ running Thetis. It is hugely helpful in setting the AGC-T.
While the Hermes does not come close to the performance and ease of use of the Flex, it does make a pretty good Field Day/POTA rig.
Submitted this idea to automate and display the AGC-T line 11 years ago. It is the top idea by votes. Maybe some day!
@Mike-VA3MW This feature seems especially relevant given the new DSP NR in 4.x.x; even a manual click-to-set-noise-floor/AGT affordance would add value to 4.x.x for 6K-series owners.
- 696 The Flea Market
- 121 Aurora
