DAX audio outboard processing for SSB/AM
Granted, DAX is primarily intended for the digital modes. Many Flex 6K users are also using it effectively for remote operations. KY6LA has a current thread discussing his method.
Perhaps DAX has merit for another purpose...
http://www.k4qky.com/audio-handling/digital-audio-processing-for-the-flex-6300 describes K4QKY's scheme for outboard software based transmit audio processing for the phone bands utilizing the Flex-6300's DAX capability.
What do you think?
Don
K4QKY
Been doing the same thing independently the day DAX was introduced. I use a Romac equalizer to fine tune the audio so that it sounds terrific both transmit and receive.
Jim, K6QE
Is there delay on the audio compared to not using DAX?
73 de Mike W9OJ0 -
Good question:
I am noticing anywhere between a half second and second delay in the audio I listen to locally to the audio I listen to over a wide area network. I am using Remaud to transport the DAX audio remotely over the Internet. However, once one gets use to it, the delay is quite easy to live with. Hopefully, all this will go away when Flex delivers the "promised land."
Jim, K6QE
Thanks for your reply Mike...
No perceptible delay with Breakaway Live set to the "low latency" setting as discussed in my article. Alternatively, you can enable ASIO4ALL driver but I prefer not to. If using other software based systems such as Ableton Live or the Live Professor VST plugin host, the ASIO4All driver is typically necessary.
Don
K4QKY
p.s. more about ASIO4ALL at http://www.asio4all.com/0 -
Jim...
For now, my software based tx audio processing with DAX audio scheme is solely for the LAN and therefore not plagued by latency issues such as what you experience over the WAN. I join with you in hopes that FlexRadio is addressing this matter.
Don
K4QKY0 -
Jim...
I'd be interested to know if Romac has effectively alleviated my perceived low end pre-emphasis issue that I discuss at length in my article. If so, please post a screen shot of your Romac settings to this thread.
Thanks and 73,
Don
K4QKY0 -
The article referenced is no longer available. Can anybody point me to instructions on making a virtual connection between my soundcard (PreSonus AudioBox 22VSL with mic connected) and SmartSDR for use in SSB/AM modes?
Thanks & 73,
Barry N1EU0
- 419 Community Topics
- 717 The Flea Market
- 225 SmartSDR+
- 472 SmartSDR for Mac
- 282 SmartSDR for iOS
- 270 SmartSDR CAT
- 225 DAX
- 397 SmartSDR API
- 143 Aurora
- 389 FLEX-8000 Signature Series
- 1K Genius Products
- 366 Tuner Genius XL
- 139 Antenna Genius
- 334 Shack Infrastructure
- 237 Networking
- 150 Contesting
- 149 Amateur Radio Interests
