Flex control issue
K2CM
K2CM ✭✭
Press Aux 1 button, control changes RIT. Un click RIT, control does not control the frequency. Can't figure out how to make the Flex Control move the frequency. Any thoughts?
  • Stu Phillips - K6TU
    edited May 2020
    Double click AUX1 to turn off RIT - same for AUX3 with XIT.
    Stu K6TU
  • Ken - NM9P
    Ken - NM9P ✭✭✭
    Yes.  Double click the AUX1 or AUX3 to turn RIT & XIT off.  But if you single click the "Big Knob" while RIT or XIT are active (light on) then you will tune the main slice frequency, but it will be offset by the existing RIT/XIT offset.  The nice thing is that with the new "Slice info panel" in the RH side panel, you can easily see what is happening to the RIT & XIT adjustments.
    BTW, I hope the updated Flex Control Knob functions are available soon.  I would love to be able to punch the AUX2 button and have it toggle TX from A to B, or toggle/cycle through making the different slices "active."  That would make things much easier for me.
    edited May 2020
    Double tap on the tuning knob will clear RIT or XIT if on - ie. set it to zero.
    Stu K6TU
  • Robert Lonn
    Robert Lonn ✭✭
    edited June 2018
    I am going to try these recommendations again in the morning of 6-7-2018,, but one would think that after shutting down SSDR program and re-booting it and the computer, everything would re-set back to normal?? When I plugged it in today, just got it, everything worked fine and Aux-1,2,3 did as instructed, main tuning know still controlled the slice frequency.. But when I added a function to the switch under the tuning knob, that is when I lost slice frequency control.. I did change it back to NONE, leaving only A1-3,,, but have been unable to recover slice tuning... Even with everything set to NONE, no control of tuning the frequencies??
    Robert
  • Jay Nation
    Jay Nation ✭✭
    edited May 2019
    Robert
    Try setting the switch function on the VFO knob, to "Tune Slice". Then a single press on the VFO knob should force it back to tuning the active slice VFO. To switch to another slice and make it active, I use AUX3 which I configured to "Change Active Slice".
    But, I prefer to use FRStacks to control the active slice, TX slice, and unmute the active slice automatically. That way the TX, and unmute follows the active slice as it changes, and can still be controlled by clicking the AUX3 button.
    #FlexRadio IRC chat
       73, Jay - NO5J
  • Robert Lonn
    Robert Lonn ✭✭
    Jay, thanks for the recommendations! I did what you said, AND IT FIXED THE PROBLEM!!!!  I understand why this would work, but if I set the main tuning knob to NONE for the push button, it must confuse something, you would think the tuning knob would just be a tuning knob for the active slice,,, seems this work around is fine and EASY to implement... Probably a already reported problem or??? In any case SSDR is working as it should... Again, thanks Jay for participating in the community and answering my request, it is appreciated!!
    Robert  WA6PHN
  • Ken - NM9P
    Ken - NM9P ✭✭✭
    edited June 2018
    Assigning the box on the big knob tells it what to do when you turn it after you have pressed the knob. If you have nothing assigned, then the knob does nothing after you press it. Then if you assign one of the AUX buttons to something like Volume or XIT, the knob tune volume or XIT after you press the AUX button. When you press the big knob it will resume tuning the frequency if you have that function assigned to the big knob’s button.
  • Jay Nation
    Jay Nation ✭✭
    edited June 2018
    Robert
    Working as it should, programmable functions often require a little programming.image
    #FlexRadio IRC chat
       73, Jay - NO5J
  • Robert Lonn
    Robert Lonn ✭✭
    edited June 2018
    True,,, but I should mention that right out of the box with NO programming the main knob did tune the slice.. It was after i programmed it that the slice tuning went away.. But after a recommendation to program the knob to Tune Slice,,, it all went back to normal operation... Used it yesterday remotely,,, nice addition to the setup..
    Robert
