beyond imagination....
Beppe IK3VIG
SmartSDR LAN architecture is very outstanding ! If you have more PCs in your LAN, install SmartSDR 1.0.24 in each PC, restart them.....the DAX client will be available in any PC for any pourpouse you want. My FLEX-6700 is running on the shack PC with two slices actives (40M and 20M). both are DAX ON in RX e TX (channel 1 and channel 2), From my office PC I'm able to see the DAX control panel with the two DAX working and both available in audio resources.,,,,,,,,WOW ! Configuring DDUTIL in office PC I was able to connect the two slices to two separate FLDIGI sessions, each of them to CAT and DAX channels......WOW ! I can work PSK or other digitals from my office PC in two separate bands without the radio close to me and without run SmartSDr in this PC. .........BEYOND IMAGINATION ! 73 Beppe ik3vig
This weekend, I was simultaneously receiving the VOA Radiogram on one DAX channel and EasyPal images on another DAX channel when I noticed an unusual signal nearby, I recognized the unusual signal as a digital voice signal, so I downloaded the latest version of FreeDV and quickly set it up to monitor the digital voice QSO. When the VOA radiogram was over I was able to make a digital voice contact. If I had opened the JT65-HF program, I could have had four slices all receiving separate signals without any interference. As stated in Beppe's post, the location of the radio is irrelevant.0
How can I use my Flex-6500 I have at home from the comfort of my office pc? Can I create a direct internet connection, I do not want to use TeamWiev or LogMeIn .... Flex amazing0
If your office PC is not connected to your LAN then you cannot connect at this time. WAN connectivity has not, as of yet, been directly implemented.0
- 417 Community Topics
- 716 The Flea Market
- 225 SmartSDR+
- 472 SmartSDR for Mac
- 282 SmartSDR for iOS
- 270 SmartSDR CAT
- 225 DAX
- 397 SmartSDR API
- 140 Aurora
- 1K Genius Products
- 366 Tuner Genius XL
- 139 Antenna Genius
- 333 Shack Infrastructure
- 237 Networking
- 150 Contesting
