I need help getting my Aurora 510 setup for SmartLink
petel22151
petel22151 Member ✭✭
My ISP is Xfinity. I use the Xfinity XB8 router. I have successfully registered my gear to use SmartLink. When I run the SmartLink Setup routine and Test the connection, the test fails and provides this feedback: "Radio cannot be accessed using SmartLink. UPnP Ports: TCP = FAIL, UDP = FAIL; Forward Ports: TCP = FAIL, UDP = FAIL; Hole Punch Supported: No"
I have run the TraceRoute routine with the following results:
Tracing route to 8.8.8.8 over a maximum of 30 hops
1 1 ms <1 ms <1 ms 10.0.0.1
2 8 ms 8 ms 8 ms 10.28.61.218
3 11 ms 10 ms 10 ms 68.86.200.45
4 10 ms 9 ms 10 ms 96.216.16.193
5 12 ms 15 ms 16 ms 162.151.163.225
6 10 ms 9 ms 10 ms 69.139.223.245
7 15 ms * 20 ms 96.110.42.129
8 14 ms 12 ms 13 ms 96.110.37.114
9 * * * Request timed out.
10 14 ms 15 ms 11 ms 192.178.45.33
11 13 ms 11 ms 12 ms 209.85.252.19
12 15 ms 12 ms 12 ms 8.8.8.8
I have read that the existence of two IP addresses in the 10.x.x.x range is likely to be my problem, since that indicates I have multiple NATs and I need a single CG-NAT configuration for SmartLink to work. Am I on the right track and, if so, what do I need to do to overcome this problem. I am not very "network literate" so if I need to ask my ISP (Xfinity) to do something to reconfigure my service I'm not clear what I need to ask for. Has anyone had experience with this problem and especially any advice on how you resolved it would be greatly appreciated!
Pete - N4PJL - PeteL22151@aol.com
  • petel22151
    UPDATE: I finally got everything working, thanks in large part to the help of a Ham-friend who is superbly knowledgeable about networking. My Xfinity ISP works fine, as does my mesh network. Most of my issues were solved by getting full access to my Xfinity router/modem and making the appropriate configuration settings that had been hidden during my initial setup efforts.
  • Gord-VA7GP
    Gord-VA7GP Member ✭✭✭
    I'm glad you got it going!
    The Xfinity line is very popular, both in the USA and also in Canada (Rogers). I'm sure quite a few others would benefit from your experience:
    I wonder if you could expand a bit on what you did, and how you did it, to explore, examine and change the router settings. And copious screenshots would be awesome (whether shot using a cellphone, or screen-grab software) - it is always helpful to see settings that worked for you, even settings you left un-changed (hahaha - because the guy you help may have changed everything, and needs some guidance to putting it all back together!).
    Thanks in-advance for sharing everything that got you going.
