I need help getting my Aurora 510 setup for SmartLink
I have run the TraceRoute routine with the following results:
Tracing route to 8.8.8.8 over a maximum of 30 hops
1 1 ms <1 ms <1 ms 10.0.0.1
2 8 ms 8 ms 8 ms 10.28.61.218
3 11 ms 10 ms 10 ms 68.86.200.45
4 10 ms 9 ms 10 ms 96.216.16.193
5 12 ms 15 ms 16 ms 162.151.163.225
6 10 ms 9 ms 10 ms 69.139.223.245
7 15 ms * 20 ms 96.110.42.129
8 14 ms 12 ms 13 ms 96.110.37.114
9 * * * Request timed out.
10 14 ms 15 ms 11 ms 192.178.45.33
11 13 ms 11 ms 12 ms 209.85.252.19
12 15 ms 12 ms 12 ms 8.8.8.8
I have read that the existence of two IP addresses in the 10.x.x.x range is likely to be my problem, since that indicates I have multiple NATs and I need a single CG-NAT configuration for SmartLink to work. Am I on the right track and, if so, what do I need to do to overcome this problem. I am not very "network literate" so if I need to ask my ISP (Xfinity) to do something to reconfigure my service I'm not clear what I need to ask for. Has anyone had experience with this problem and especially any advice on how you resolved it would be greatly appreciated!
Pete - N4PJL - PeteL22151@aol.com
UPDATE: I finally got everything working, thanks in large part to the help of a Ham-friend who is superbly knowledgeable about networking. My Xfinity ISP works fine, as does my mesh network. Most of my issues were solved by getting full access to my Xfinity router/modem and making the appropriate configuration settings that had been hidden during my initial setup efforts.0
I'm glad you got it going!
The Xfinity line is very popular, both in the USA and also in Canada (Rogers). I'm sure quite a few others would benefit from your experience:
I wonder if you could expand a bit on what you did, and how you did it, to explore, examine and change the router settings. And copious screenshots would be awesome (whether shot using a cellphone, or screen-grab software) - it is always helpful to see settings that worked for you, even settings you left un-changed (hahaha - because the guy you help may have changed everything, and needs some guidance to putting it all back together!).
Thanks in-advance for sharing everything that got you going.
- 419 Community Topics
- 717 The Flea Market
- 225 SmartSDR+
- 472 SmartSDR for Mac
- 282 SmartSDR for iOS
- 270 SmartSDR CAT
- 225 DAX
- 397 SmartSDR API
- 141 Aurora
- 1K Genius Products
- 366 Tuner Genius XL
- 139 Antenna Genius
- 333 Shack Infrastructure
- 237 Networking
- 150 Contesting
- 149 Amateur Radio Interests
