Slice location
Is it possible to move a slice location or define a specific location for each slice. I run 6700 using 8 slices.
  • VE7ATJ_Don
    VE7ATJ_Don Member ✭✭✭✭
    Hi Hawkeye… I don't believe there is any way to specifically define where each slice goes, but I find that SmartSDR and/or Windows 'remembers' what it looked like when you close SmartSDR and reinstates the same UI when the app is restarted.
  • David Decoons, wo2x
    you can rearrange the panadapters or even unpin them from the main program. If you unpin them you can then rearrange wherever you want.
    73 Dave wo2x
