Smart SDR not connecting to Power Genius
A couple of days ago, Smart SDR stopped connecting to my Power Genius unit. It is still connecting to the Tuner Genius with no issue. I am running ver. 4.2.20 of SmartSDR on Windows 11. I was running an earlier version of the Power Genius firmware before and immediately after the issue arose. To try and fix it, I upgraded the Power Genius to the latest ver. 3.8.9 firmware, but the problem continues. I can however connect to the Power Genius using the Power Genius utility program, which confirms the unit is available on the network and which lets me switch the unit from standby to operate and back. Any ideas on what could be the cause for this and what the fix is are appreciated.
  • Erik Carling EI4KF
    Have you reset the PGXL (power on while holding in the standby/operate button and press the screen dots 3 times)? May not help but worth a try.
    The latest version F/W by the way is either 3.9.1 https://4o3a.com/support/downloads#
    or 3.9.2 depending on whether your PGXL is SO2R or 3WAY.
  • David Decoons, wo2x
    Flex has not certified 3.9.1 yet and there are no release notes on what it addresses.
