No internet on the Aurora
Sorry Aurora have no internet0
Hi Kenneth… can you give us a bit more information on what you are experiencing/expecting?
Are you saying you can't connect to your Aurora?
Are you trying to connect remotely or via your local WAN or via direct cable?
We need a bit more information to help you out.
The aurora connects via hard wire network cable to your home network either a switch or a router. In itself it has networking but internet would be provided by your home internet service. Aurora in it self does not require internet except perhaps to purchase extended software features (V4.x) or for smartlink remote access. Aside from those it uses your home network to run if you use a Maestro or a computer to control it.
good evening sorry for the late response however they not communication between the Maestro and the Aurora. when i go in the menu in the Maestro and select Radio they no info on the Aurora, no Serial#: no Region no license info.
in Network the Maestro have an IP address, the radio have nothing no ip address no mast no MAC address
in the menu column
AUDIO, TRANSMIT,TX BAND SETTINGS AND ALL THE OTHERS ARE EMPTY PROFILE EMPTY0 -
in the menu column
Yes i am trying to connect to the Aurora via the network, and direct from the Maestro to the Aurora, Maestro have no info on the Aurora, no network settings. no Region, no Serial#, nothing and that is from the Maestro connected directly to the Aurora0
message on the Maestro
The radio does not have an Internet connection. An internet connection is required to configure Smartlink
the network cable is conneted and working, have internet green light on the switch flashing both green lights, one green light on at the back of the Aurora and its not flashing0
