How to add Bluetooth headset capability to the Maestro
Here is a simple way to add Headset Bluetooth to the Maestro
What is needed is a Bluetooth receiver/transmitter which is capable of full duplex operation.
Most receiver/transmitters I have seen out there will only do receive or transmit, but not both at the same time.
ClearSounds makes a Bluetooth stereo transceiver that is full duplex
It is the ClearSounds Qconnect CLG92. Around $37.00 from Amazon
One will need to build a cable that plugs into its stereo 2.5mm jack which then breaks out into the Maestro speaker and microphone jacks.
The tip of the Qconnect plug wires to the tip of the Maestro mic plug. The center conductor of the Qconnect plug wires to the tip of the Maestro speaker plug. Both shields from the Maestro plugs terminate at the shield of the Qconnect plug.
Simply pair the CLG92 to your Bluetooth headset and you will have full duplex operation for use with your Maestro.
I am using the Plantronics Voyager 104 which works very well and has a nice long boom on it.
The Blueparrott B450-XT also works very well.
Some of the cheaper headsets on Amazon also work but can sometimes exhibit a tone on the microphone audio
and clicking noise on receive audio. One needs to experiment here.
I recommend staying with headset with a long boom on it. Bluetooth noise canceling can be aggressive at times and using a headset with the microphone located at the ear can sometimes lead to hollow “underwater” type mic audio.
Bluetooth mic audio tends to be a little on the narrow side but can be enhanced if desired by using the transmit EQ. With this headset I find sliding the 63Hz and 125HZ all the way up to 10 then setting the 250Hz to around 4 works well. Xmit bandwidth 0Hz to 3200Hz.
A little dip at 500Hz and slight peak at 2Khz. This is all personal preference.
Attached is a picture showing the back of my Maestro.
The Qconnect is shown wired to the microphone and speaker jack of the Maestro
Also show is a remote camera shutter release that I use for a wireless push to talk.
I also use a 12vdc battery pack with Velcro to the back of the battery door.
JerryW1JWC
Great! Thanks for the information. I will try it in the 6600 box as well. I have a pair of Bose Bluetooth headphones that work with my phone and laptop. I tried to use them with rigs but the Bluetooth TX wouldn't pair. I use my headphones with Morse Runner and RemoteHams. FYI, I am getting conflicts with multiple Bluetooth devices that I use.0
Has anyone recently found a full duplex Bluetooth adapter that works with the Maestro?
The one mentioned in the thread (ClearSounds Qconnect CLG92) is no longer available.
Stuart.
WA5US0 -
I find it very simple for FRS to natively implement BT on base on all Tablets the BT is functional, I do not understand why the Development team does not implement this interesting functionality would allow us users to use BT systems such as the 4O3A NC-1 headset and other wireless headphones.
About to buy a Maestro and can't believe that native BT isn't available which is making me rethink the purchase. I mean, its been years this has been requested. What the heck is the holdup??0
For what it's worth, Flex has stated that the current "C" model Maestro actually HAS BT capability incorporated. And that they may or may not activate/ implement it some time in the future. The statement was in at least one of the YouTube videos describing it around the time of it's release.
73 Russ KR6W
- 688 The Flea Market
- 457 SmartSDR for Mac
- 105 Aurora
- 998 Maestro
- 972 Genius Products
- 133 Antenna Genius
- 846 Peripherals & Station Integration
