Changed band from 40m to 60m and the radio rebooted
Conny
SmartSDR-macOS V2.9.130, D4.2.08 C:US-en fw:3.10.15 r:FLEX-6600M running on arm64 on macOS Version 26.5.2 (Build 25F84)
Changed band from 40m to 60m and the radio rebooted (power switch steady green -> flashing red -> flashing green -> steady green.
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsReset the radio to reset the database after exporting and saving your profiles.
Test again and if it sill happens, you'll need to open a support ticket.
As Mike stated, export your profiles and then do factory reset of the radio. Test band changes.
Once you test everything is working import your profiles. When it asks what you want to import, uncheck Preferences. This will reset the persistence database.
73 Dave wo2x0
- 685 The Flea Market
- 102 Aurora
- 994 Maestro
- 970 Genius Products
- 357 Tuner Genius XL
