What Happen To 4O3A.com?
Currently many of this links from FlexRadio to works with Flex such as the Tuner Genius are no longer working? If you go to the site it does not contain the same content it had and looks way scaled back. If you go to https://4o3a.com you get a Coming Soon notice and then only a few items for down load such as TGXL v1.2.17 and its manual then don't get it work receiving Low RF Power changing regular power or tune power has no effect. Also at time has asked that the firmware be reloaded but then later has a similar issue after being upgrade successfully?
  • David Decoons, wo2x
    They are in the process of redesigning their web site.
    73 Dave wo2x
  • Erik Carling EI4KF
    If you are in process of a support ticket with them, or need to communicate urgently, an email to admin@4o3a.com should elicit response. Both Dragan and Dragisa have been communicating with me via this method pending the completion of their website update.
