PGXL New Firmware
I am probably so far behind the curve that this was known to everyone but me. Flex announced firmware 3.8.9 back in December 2024 but I cannot find anything about the latest releases.
Anyway, in case you don't know see https://4o3a.com/support/downloads
for PGXL SO2R Firmware 3.9.1 and PGXL 3-Way Firmware 3.9.2
  • David Decoons, wo2x
    3.9.1 has not been tested or certified by Flex. I have not seen any release notes on 3.9.1 to see what it addresses.
    If you purchased your PG XL from a distributor other than Flex, check with your distributor’s support on what the difference is and if you should upgrade your PG XL.
  • Erik Carling EI4KF
    edited July 7
    My distributor doesn't know. But 4O3A does.
    403a.ico 3way.ico
  • WX7Y
    WX7Y Member ✭✭✭✭
    Hello Erik, I have been testing the 3.9.1 for a few weeks now on my FLEX station and I seem to have less Interlock issues, when I do have it interlock most of the time it fix's itself on the next transmission. I think there has been only one time I have had to power down everything to get the interlock to reset compared to once every other day or more.
    It seems to work at least for me better.
    I think Since FLEX and 4O3A split the sheets they are not communicating very much so getting them to approve new firmware may take a LONG time if ever, I do know the TGXL firmware update took a VERY long time if ever to get on the approved list.
    Be careful and get the correct model firmware because I see they are now building or soon will be a Multiport and HIGHER power versions of the PGXL which will un-doughtily have different firmware!
    Hi Bret, I had no idea it had been available for weeks. Nobody said anything so far as I know, though I may have overlooked a notification. I only found out because I was communicating with 4O3A about my PGXLs. However, thanks for letting us know of your experience and that is good to know.
    Yes I will be sure to check the correct model FW, I have the 2R and the 3Way and have the right downloads for each of them.
    Apart from the hardware, I really like the 4O3 support. There is none of this "we appreciate your patience" canned garbage. They talk to you like a valued customer.
