Less mouse clicks to switch from Ant 1 to Ant 2 and back to Ant 1 ?
Perhaps a minor issue for most but I am frustrated that SmartSDR requires me to first click on the current active antenna in order to then select 1 or 2 to change to the desired antenna . Can I create a keyboard shortcut to save that extra mouse click, simply press a key and instantly get the switch accomplished ? When doing antenna A/B tests , this would be useful .
Andy K3UK
