temperature 520M
Arnold Goldman
Member ✭✭✭
in Aurora
is it ok to leave the 520M on 24/7 tremperature online SDR is way about 30 degrees on stby leaving it on?? tnx
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsYes, no problem at all. Mine has been on every day since August. The transmitter runs ice cold even in TX. :)
tnx for quick reply i also noticed that the temp scale is NOT on the maestro just on regular SDR; again old fashioned so still with the front panel on the 520M and remote i use the maestro; just a quick comment i wish you kept the older style J45 plug on the maestro C; cabling up mike is just not as easy on the C like on the B; just a note tnx as always; and once in a while i have to reboot the 520M with the white button; maybe a router / internet shutoff
