DAX 4.2
I just downloaded the latest update SmartSDR v4.2.20 (from SmartSDR v4.2.18). The DAX v4.2.20 is activated but the RX Stream does not show the usual receive levels from the audio in the Flex 6400M. The button is blue with the correct ANT1 link and the radio functions fully on receive, just nothing shown in the DAX box. Any help with this would be appreciated. 73, Joe, WA2PJI
Thank you for the comments! The problem was resolved once I adopted the new naming conventions in WSJT-X with the upgrade to v4.2. There is a great video that focuses on these changes:
SmartSDR DAX 4.2 - New Performance Changes - ***User Actions Required***
When the button is blue there is no attached client. Launch WSJTx / JTDX, correctly set up for the new naming in v2, and the button will turn green with the receive level shown too.
Thank you, Erik. I will check it and, hopefully, it will fix the problem.
Joe
WA2PJI
In addition to Erik's answer, I would also check that the DAX channel number in WSJT-X or JTDX matches what's set in SmartSDR. The naming changed slightly in v4.2 so it's worth a quick look.0
