Power Output Drop and Calibration Issues on Flex 8400M
I am opening a ticket to request technical assistance for my Flex 8400M but while I'm at it I'll also expose it to the community:
The radio is experiencing a significant and band-selective
drop in RF power output. Although 100W is selected in SmartSDR, the
actual power output varies drastically across bands:
- 20 meters: 95W (Near full power)
- 12 meters: 93W (Normal operation)
- 17 meters: 81W
- 15 meters: 75W
- 10 meters: 70W
- 6 meters & Low Bands (40m/80m): 50W (Strictly locked / Power Foldback)
The
fact that the radio can deliver over 90W on certain bands proves that
the LDMOS final transistors are physically intact. However, the severe
degradation on other frequencies suggests either a corrupted PA
Calibration Table in the firmware or an efficiency issue with the
internal Low Pass Filter (LPF) relay matrix.
Troubleshooting steps already performed:
- Power Supply Check: Checked with a heavy-duty power supply. Voltage remains rock-solid at 14.2V under load, with no voltage sag.
- Antenna & SWR Check: Antennas have been verified using a VNA. For instance, on 6m, the SWR
is 1.38:1 with a purely resistive impedance, yet the radio still limits
output to 50W. - Software Configuration: Checked
TX Band Settings; all bands are set to 100% max power. DAX audio
streaming from JTDX (FT8) is working properly and driving the TX stream. - Deep Factory Reset: Performed a full hardware factory reset (holding the power button until
the LED turned solid White). The issue persists even on a clean,
default profile database. - Diagnostic LED Flash: During one of the reboot cycles after the reset, the radio temporarily halted and threw a "1 Red Flash" error code (Fan/thermal controller alert) before booting up again.
Given
these symptoms, it seems the radio needs a forced PA Gain and Power
Calibration Routine via a remote session, or a physical inspection of
the LPF board.
On 17 meters, the SWR is a perfect 1.1 with 0.0W reflected and a
rock-solid 14.6V on the PA. However, the output is limited to 81.0W.
This is the definitive mathematical proof that the issue is strictly a
corrupted internal software calibration (PA Gain Table) and has nothing
to do with external antenna factors or foldback protection."
Best regards,
Riccardo
Riccardo, are you testing on a dummy load or live antenna (regardless of actual SWR readings). The support team will want to know as you don't mention what your test setup is.
But, it does sound like your radio may need to come home for a spa day.
Actual RF power out can be affected in many ways, now just the finals. It can be related to components in the LPF or the ATU.
Hi Mike,
Live antenna with purely resistive load measured with VNA0 -
You still need to get on a dummy load.
I am having a similar issue with my just purchased Pre-loved 8400. Three bands don't give full power output but not quite as bad as yours. 12, 15 and 20 meters I only get out around 82 watts where all the other bands do full power. I haven't tried on a dummy load yet but I will. I really hope I don't need to send it back since I just got it a couple days ago and am enjoying using it.
Burch
K4QXX
Before Submitting a Power Output Concern
To avoid unnecessary bench fees, please complete the following tests before sending your radio in for service. If we cannot reproduce the issue, a bench charge may apply.
Test Setup Requirements
- Set TUNE to 100%
- Connect to a quality dummy load rated for your power level using a good quality patch cable. New 100W dummy loads are available from DX Engineering for around $50.
- Use a quality wattmeter that covers all HF bands
- Set the ATU to OFF or BYPASS
- DC supply voltage must be 13VDC or higher while transmitting in TUNE mode. You can verify this in real time using FRStack (mkcmsoftware.com/Flex/Index). Supply voltage during transmit directly affects RF power output. The radio is designed to operate up to 15VDC (13.8VDC +/- 15%).
Measurement Procedure
Sweep through all bands from 160m to 6m using the TUNE function and record your power readings for each band. If using a smaller dummy load, monitor it for heat and allow adequate cool-down time between bands.
What to Expect
A variance of +/- 10% from the rated 100W output is within normal operating tolerance and is not considered a defect.
Opening a Support Ticket
If you still believe there is an issue after completing these steps, open a support ticket and include all of your recorded measurements along with your test setup details. This will help us assist you as efficiently as possible.
Why the Difference Between 90W and 100W Is Insignificant (sorry for the rant) :)
The relationship between transmit power and perceived signal strength on the other end is logarithmic, not linear. This is measured in decibels (dB), and the math tells a very clear story.
Going from 100W down to 90W is a loss of just 0.46 dB.
To put that in perspective:
- The human ear (and the S-meter on the other station's radio) cannot detect a change of less than 3 dB under any practical operating condition
- 3 dB requires halving your power, dropping from 100W to 50W
- 6 dB requires dropping to 25W before most operators would describe it as a noticeable change in signal
- Even a full S-unit (6 dB) is considered only a marginal difference in actual copy on a real HF band
So a 10W difference at the 100W level is, in practical terms, completely inaudible. The noise floor of a typical HF band, QSB fading, and atmospheric variation will all mask that difference many times over.
QSB Fading Dwarfs Any Power Difference
Here is the part that puts it all in context. On a typical HF path, QSB (selective fading) routinely causes signal level swings of 10 to 20 dB or more over just a few seconds. That is the equivalent of your signal fluctuating between 100W and 1W repeatedly, completely beyond your control. Against that backdrop, a 0.46 dB difference from a 10W power variance is not just small and it is entirely invisible. The band is doing far more to your signal than your power output ever could.
A helpful way to think about it:
You would need to reduce power from 100W to about 79W just to lose a single dB. Nobody is going to hear that either.
The takeaway is simple: if your radio is putting out 90W instead of 100W, your signal on the other end is identical for all practical purposes. Focus your energy on antenna efficiency, feedline loss, and operating technique — those factors move the needle far more than a 10% power variance ever will.
Well said. Also goes the other way for amplifiers. 100 watts to 400 watts is 6 dB, 1 S-unit.
It comes from my Aurora pitch and the difference between 500 watts and 1500 watts. It sounds like a lot but it isn't.
New Flex owner here.
A google search has brought me here. :)
Been a Ham for 35 years.
Purchased this a couple months ago.
I'm also seeing a variance of power output from my Flex 8400M.
My results into a dummy load are as follows.
10m - 98 watts
15m - 93 watts
20m - 84 watts
40m - 92 watts
80m - 97 watts
160m - 91 watts
This is my first SDR radio.
I understand the difference between 84 watts and 100 watts is only about .75 db.
Not worth starting a ticket over.
I'm just used to my other "older" radios putting out 100 watts, on all bands, as advertised.
So my concern is that my PA is going to have an issue in the future or is this just the nature of SDR radios?
Again, my first SDR radio.
I absolutely love the radio, I also have the Tuner Genius.
Don KI0EO0 -
What was your DC Voltage under full load?
Mike,
My DC voltage is at 13.8 volts.
DC voltage doesn't fluctuate at 100watt transmit.
I'm pulling right around 20 amps.
I do have another power supply to try.
Don KI0EO0 -
Good data point. If you want your 20M issue looked into, you will have to open a support ticket and they will update you on the next steps.
Update on this thread.
I was getting the values for the power output from the 8400M and also the Tuner Genius.
I have a Palstar AT2K tuner that I know is pretty accurate.
When I connect that between the 8400M and a dummy load I get these results.
10m - 100 watts
15m - 98 watts
20m - 92 watts
40m - 94 watts
80m - 94 watts
160m - 90 watts
It appears that there is a small calibration issue with the 8400m PWR meter.
Not a big deal in my world.
My next purchase will be a good, high quality independent watt meter. :)
Don KI0EO0 -
I doubt it is a calibration issue on the Radio, as it is calibrated before it leaves the factory.
The SWR/Power meter in the radio is an actual MiniCircuits appliance into both a calibrated load(s). Likely both 50 and 25 ohms (I'll need to check). I would trust it over anything without a calibration stamp on it.
Okay, Mike,
I purchased a 200W dummy load.It'll arrive tomorrow.
I'll run all the tests you described and send you the screenshots.
BR.
Riccardo
Hi Mike,
these are the results with a pure resistive dummy load 50Ohm 200w,
I attached a zip file with all the screenshots of the tests
6MT: 59W
10MT: 74.3W
12MT: 77.6W
15MT: 84W
17MT: 87.5W
20MT: 96.3W
30MT: 93.7W
40MT: 92.2W
60MT: 90.4W
80MT: 94.2W
160MT: 93.9W
73 de IU2RPE
Ricky
I started a ticket on this.
My earlier post stated I was pulling 20 amps from my supply, that is incorrect.
I'm pulling 10 amps.
My 20 meter output has now dropped to 80 watts and the 17 meter band is a little better than that.
All other bands are at or close to 100 watts.0 -
Hi Mike,
Today my radio is leaving to go to Norbert's spa.0
- 398 Community Topics
- 678 The Flea Market
- 191 SmartSDR+
- 392 SmartSDR API
- 91 Aurora
- 988 Maestro
- 962 Genius Products
- 352 Tuner Genius XL
- 317 Shack Infrastructure
- 222 Networking
