6600 4.2.20 & WJST-X Waterfall Blown Out
I followed the video on setting up WJST-X with the new DAX. WJST-X is working but the waterfall is always blown out.
I set the RX nearly all the way down. The slider stays the same, but the little db graph goes higher and higher (while the slider stays at 5). The WJST-X waterfall colors get blown out and the db graph in WJST-X rises up to 60.
It is as-if it is dynamic.
What is causing the RX to continually adjust up.? How do I prevent this and make it stick to where I drop the slider?
Without screen shots, my questions are 1) do you have AGC off by chance? and 2) have you correctly set AGC-T? I'm wondering if there is too much audio input into WSJTx.
Erik, you nailed it. Somehow my AGC went to fast and was around 80 on the slider.
What are the recommended slider settings for SLOW/MED/FAST?0
- 685 The Flea Market
- 102 Aurora
- 994 Maestro
- 970 Genius Products
- 357 Tuner Genius XL
