6600 4.2.20 & WJST-X Waterfall Blown Out
I followed the video on setting up WJST-X with the new DAX. WJST-X is working but the waterfall is always blown out.
I set the RX nearly all the way down. The slider stays the same, but the little db graph goes higher and higher (while the slider stays at 5). The WJST-X waterfall colors get blown out and the db graph in WJST-X rises up to 60.
It is as-if it is dynamic.
What is causing the RX to continually adjust up.? How do I prevent this and make it stick to where I drop the slider?
  • Erik Carling EI4KF
    Without screen shots, my questions are 1) do you have AGC off by chance? and 2) have you correctly set AGC-T? I'm wondering if there is too much audio input into WSJTx.
  • W4RXK
    W4RXK Member ✭✭
    Erik, you nailed it. Somehow my AGC went to fast and was around 80 on the slider.
    What are the recommended slider settings for SLOW/MED/FAST?
