Webroot SecureAnywhere
Just as a heads up, we have had a couple of customers using Webroot SecureAnywhere software that submitted helpdesk tickets that detailed extremely slow (5 min) startup times with SmartSDR v4.2+. If you use this software, the solution is to add the SmartSDR executables to the SecureAnywhere whitelist (exemption). I figured I would put this note here on the community in case other people run into this to save them some time getting to a solution.
Just wanted to push this to the top again as we continue to see helpdesk tickets with this issue. If you are trying to run SmartSDR v4.2+ and you're running Webroot SecureAnywhere, you may experience SmartSDR looking like it isn't starting. In reality, it is being put into "monitor" status by SecureAnywhere's Active Process Protection where it stays for ~5 minutes.
If you are having trouble starting SmartSDR with the latest version, check for this.
We have initiated conversations with Webroot in order to get SmartSDR whitelisted and will see if that helps moving forward.
Good news: We heard back from Webroot today that thanks to logs submitted from several of our customers, SmartSDR is now whitelisted and this shouldn't present a problem moving forward.
- 685 The Flea Market
- 102 Aurora
- 994 Maestro
- 970 Genius Products
- 357 Tuner Genius XL
