Mounting 8600 on its side / Under Desk PC Mount
I just purchased a new sit/stand desk with a couple under desk PC mounts.
As I was hoping, the under desk PC holder was adjustable enough that it would hold an 6600/8600 perfectly.
Are there any issues with the 6600/8600 oriented this way?, I wouldn't think so.
An Aurora would make this the ideal minimalist operating desk.
I currently have a rack mount for all the equipment. This requires the extension of the cables for the cw paddle, speakers, headset etc. With the 6600/8600 under the desk I only need to have a couple coax cables go from the rig to the PGXL. All the other cables are self contained on the desk and can reach the 6600/8600 without extensions.
Now to find a good location for a power supply on the desk. An Aurora wouldn't have this problem.
Rich - N5ZC
As long as the fan outlets are clear, I can't see any reason this wouldn't work perfectly. Just make sure (as I think it is) that the front panel is visible so you can see the lights during startup, in case there are any 'red' flashes… :-)
One of the advantages of having a "non-M" version.
I took delivery of an Aurora AU-520. Going minimalist in equipment. I sold the PGXL and TGXL.
This setup is dead quiet, as in no fan noise. I did quite a few tests using the PGXL at the 400 watt level and there may have been one instance when more power made a difference. I may regret going from a KW to 200 watts on 6m, but that's ok I'll just have to depend on propagation and the antenna.
The desk is a Secret Lab Magnus Pro with two under desk pc mounts.
The left PC mount holds the AU-520 and the right PC mount holds a Dell Alien ware Aurora. It was a coincidence that the PC has the same name as the AU-520.
I'm attaching two images. One with the desk in stand up position and the other in the sit down position.
Now to find a home for no longer needed enclosed rack.
Nice setup Rich!
Thank you Len.
Rich - N5ZC
I like it,,looks good Rich.
- 691 The Flea Market
- 197 SmartSDR+
- 462 SmartSDR for Mac
- 113 Aurora
- 978 Genius Products
- 136 Antenna Genius
- 323 Shack Infrastructure
- 228 Networking
