SmartSDR v4.2.20 question
Well I've upgraded from
SmartSDR v4.2.18 to the new SmartSDR v4.2.20, did everything I was supposed to including a cold reboot - twice, rebooted the computer.
I do not see the new features, band edge, or noise filter goodies. What am I doing wrong? I shows the proper software version below and I even hit the refresh button. I do not see any changes this this version!
Hi Ken, did you purchase SmartSDR+?
If you purchased it, is your radio connected to the Internet? If not, you need to have it on a LAN segment that has Internet access. Once the license is verified, you can remove Internet access.
Yes the radio is connected to the internet.
Also this radio is a 8400.
Yes, back on 10/30/25 for Version 4
I don't see anything new either . Yes I have smartsdr+ I bought mine after Ken did.
It shows in radio setup.
My 6400 is also doing the same thing.
Click on the DISPLAY Tab on upper left, Scroll down to Band. Set it to your IARU region and then turn it on.
You will need to select and activate whichever other features you are interested in by visiting the appropriate area you are interested in. For example the Filters may now be customized by selecting SETTINGS at the top of SSDR and then select the RADIO Tab and then select the FILTERS Tab and there you can adjust those. and so on.
Regards de K1UO Lar
Ok - TNX! That is what I needed.
Does this work on a Maestro C?
As long as you have updated the radio and then tried connecting with the Maestro, then the Maestro should update as well. Then, you should have the same selection available.
I'm early access and I don't see them. I'm sure it's operator error!
Look at Larry's post above. That will tell you how to access the new features.
I still don't see the NR and NB sliders. I'll keep looking!
Keep waiting as well. The different DSP sliders have not been made available yet. ( maybe to Alpha testers, but not to anyone else)
- 397 Community Topics
- 677 The Flea Market
- 189 SmartSDR+
- 216 DAX
- 390 SmartSDR API
- 87 Aurora
- 330 FLEX-8000 Signature Series
- 987 Maestro
- 871 FLEX Series (Legacy) Radios
- 959 Genius Products
- 351 Tuner Genius XL
- 131 Antenna Genius
- 316 Shack Infrastructure
- 221 Networking
- 478 Remote Operation (SmartLink)
- 840 Peripherals & Station Integration
