SmartSDR v4.2.20 question
Ken
Ken Member ✭✭
Well I've upgraded from
SmartSDR v4.2.18 to the new SmartSDR v4.2.20, did everything I was supposed to including a cold reboot - twice, rebooted the computer.
I do not see the new features, band edge, or noise filter goodies. What am I doing wrong? I shows the proper software version below and I even hit the refresh button. I do not see any changes this this version!
    Hi Ken, did you purchase SmartSDR+?
    If you purchased it, is your radio connected to the Internet? If not, you need to have it on a LAN segment that has Internet access. Once the license is verified, you can remove Internet access.
  • Ken
    Ken Member ✭✭
    Yes the radio is connected to the internet.
  • Ken
    Ken Member ✭✭
    Also this radio is a 8400.
    HI Ken, did you purchase SmartSDR+?
    You can tell by looking at the Radio tab on the Radio Setup screen.
  • Ken
    Ken Member ✭✭
    Yes, back on 10/30/25 for Version 4
  • Terry K7NY
    Terry K7NY Member ✭✭
    I don't see anything new either . Yes I have smartsdr+ I bought mine after Ken did.
    It shows in radio setup.
  • Ken
    Ken Member ✭✭
    My 6400 is also doing the same thing.
  • Ken
    Ken Member ✭✭
    This is what my screen looks like:
  • K1UO Larry
    K1UO Larry Member ✭✭✭
    edited June 3
    Click on the DISPLAY Tab on upper left, Scroll down to Band. Set it to your IARU region and then turn it on.
    You will need to select and activate whichever other features you are interested in by visiting the appropriate area you are interested in. For example the Filters may now be customized by selecting SETTINGS at the top of SSDR and then select the RADIO Tab and then select the FILTERS Tab and there you can adjust those. and so on.
    Regards de K1UO Lar
  • Ken
    Ken Member ✭✭
    Ok - TNX! That is what I needed.
  • W4AFK Bruno
    W4AFK Bruno Member ✭✭
    Does this work on a Maestro C?
  • Trucker
    Trucker Member ✭✭✭✭
    As long as you have updated the radio and then tried connecting with the Maestro, then the Maestro should update as well. Then, you should have the same selection available.
  • stevenab
    stevenab Member ✭✭
    I'm early access and I don't see them. I'm sure it's operator error!
  • Trucker
    Trucker Member ✭✭✭✭
    Look at Larry's post above. That will tell you how to access the new features.
  • stevenab
    stevenab Member ✭✭
    I still don't see the NR and NB sliders. I'll keep looking!
