PGXL shows up on Maestro. Active/Standby marks but amp wont TX
Need some help. On the Maestro C and 4.2.2 SSDR by now, I power up the amp via remote relay for the 240VAC power.. The Maestro screen shows the amp is there on standby, and if I click to run the amp it shows that it is on-line. However, there is no amp power, its as if it is still on standby. This happens on the same network as the amp and remote locations.
Using the PC SSDR 4.2.2 on the same network as the amp it works normally.
I downgraded to 4.1.8 thinking it was a 4.4.2 issue but the problem remains, I went back to 4.4.2 now
I also cannot get the amp talking to an iPad and Im listing a message on the iOS board now as well.
Ive spent hours testing remote, local, up and down on SSDR…. This worked fine 2 months ago, last time I used the MaestroC. The amp is on the latest sw 3.8.9
Any insight on this?
Found iOS instructions for PGXL, will try it before posing anything on the iOS area.
Local PC and Ipad work the amp. But Maestro C, lets me standby or activate the amp. however, the amp does not transmit. Any idea whats wrong?
- 681 The Flea Market
- 394 SmartSDR API
- 98 Aurora
- 991 Maestro
- 965 Genius Products
- 353 Tuner Genius XL
- 319 Shack Infrastructure
- 224 Networking
