JTDX no longer working after SSDR update
Hi all
I just did the version 4.2.20 update that went smoothly.
BUT JTDX no longer works. All settings were unchanged, so they should have worked immdiately. I no longer have reception in the wide graph, and the lower right indicator on JTDX shows no signal.
What could have changed in the Flex settings ?
TU + 73
Paul F6EXV
I did not get it right in your last question so the answer here is probably something other than:
In the SSDR Slice Flag, is DAX set to Channel 1?
Is DAX set to on in the Phone/CW Panel (right hand side of UI)?
In the SSDR DAX Panel, RX Streams, is Channel 1 lit green showing it is on and streaming?
In JTDX Settings>Audio, the correct end point is still set (DAX RX 1 FlexRadio DAX)?
Monitor is on in JTDX?
Hi Erik
I think you pinpointed the problem. The answer to your questions is yes to all, except the one about the SSDR DAX panel.
There, Chanel 1 is blue, and does not seam to be streaming. The IQ Stream #1 is blue onb the lower part of that panel, and says "ready".
How do I correct that please ?
TU + 73
Paul F6EXV
- You definitely actually have DAX channel "1" assigned to your active receiving Slice. Open the Slice Flag menu and ensure DAX 1 is selected.
- JTDX is running and the correct end point is set in Setting>Audio>Input? If not, the DAX button will be Blue because nothing is connected to it.
- If one of the above is not the reason, close JTDX and close DAX. Reopen DAX and JTDX. Any change?
Here is what I got in JTDX. I believe this is correct.
I closed both JTDX and DAXC, reopened… no change… I even rebooted the computer to no avail.
Paul, that is not correct. Click the down arrow on the right hand side of Input and select DAX RX 1 (FlexRadio DAX)
Bingo, you nailed it !
My previous setup was working with DAX Audio RX1, so the SSDR update must have changed something there…
Thanks a lot Erik !
Paul F6EXV
You are welcome. AH1A still the best DXped from Baker & Howland ☺️
I replied too fast… I do have reception and decoding, BUT no power out when TXing.
The PTT does work, the slider on JTDX is all the way up. I have once again restarte'd both SSDSR and JTDX.
The RF power on SSDR is at 100, on JTDX the Pwr is also all the way up. I do get power out on a SSDR tune, but not on a JTDX tune…
Where to look please ?
Paul F6EXV
Have you changed the JTDX Output to DAX TX (FlexRadio DAX)?
Now I have ! First QSO XX9TXN ! So it does work 100%
Thanks Erik !
Paul
