I purchased Smart SDR on My IPhone but can’t get it on my IPad mini 2
Does anyone know the answer
HI
First, make sure you are using the same apple-id for both devices
and
Second, that you are on the latest ios for all your ios devies
but
i think ipad mini2 is stuck at ios 12.1 i and can not be able to updated to latest ios (ipad ios 15.7)
and
that may be your issue
Paul K3SF
[{"insert":"Good morning \nMy Apple ID is the same but the IPad is at the latest version for the Mini which is 12.5.6.\nDoes that mean I need a newer IPad?\n\nThank you for your response. I appreciate it.\nNick KY4Q\n"}]0
Hi
yes...
i have run into tha same issue here with ipad2
you will need a newer ipad that runs latest ipad ios...
apple will be releasing new ipads in Oct 2022....
as well asupdate to ipad ios v16
here is article that show what ios devices will suport io16 come late october 2022
https://www.wired.com/story/apple-iphone-ios-16-ipados-16-new-features/
i also have ipad pro with latest ipad ios and it runs iosssdr no problem
and
i had iphne12 that also ran iosssr
and
i just updated to iphone14 with great deal from verizon
hope this info helps
Paul K3SF
The iPad mini 2 32GB Model A1455 is functional for SSDR
they both need to be on the same Apple user account if I remember right
I don't want to use it as a remote but rather at home with the same wifi network
As above, should be able to acquire any other version through the same account on the store.
