Subject: BF-100 no longer works with SmartSDR 4.2.18 (Flex 6700)
AK1MD
in SmartSDR CAT
Hi all,
Has anyone else had problems with the SureFire BF-100 bandpass filter after updating to SmartSDR 4.2.18?
I use a Flex 6700 with the BF-100 connected via FTDI USB cable (C232HD) on the accessory port. It worked fine on previous versions.
Now:
- When USB cable is set to Bit mode → Panadapter works normally (signals visible), but the BF-100 does not switch bands at all.
- When set to CAT mode → No signals in the panadapter and BF-100 does not switch.
Anyone else seeing this with 4.2.18 + BF-100? Any solutions or workarounds?
Thanks, 73, AK1MD
In CAT, highlight the CAT 'channel' you are using.
Then, click on the LOG at the bottom of the screen. There, you can see the commands being sent, or not sent.
Run some band changes and capture all the data and drop it into an AI like Claude or ChatGPT and ask it to analyze it for you. It will know the differences, but it does help if you tell it what you are doing and with what hardware.
- 394 Community Topics
- 671 The Flea Market
- 178 SmartSDR+
- 453 SmartSDR for Mac
- 276 SmartSDR for iOS
- 216 DAX
- 389 SmartSDR API
- 81 Aurora
- 982 Maestro
- 956 Genius Products
- 475 Power Genius XL Amplifier
- 350 Tuner Genius XL
- 131 Antenna Genius
- 312 Shack Infrastructure
- 218 Networking
- 836 Peripherals & Station Integration
- 146 Amateur Radio Interests
