New 3rd Party App: ControlDeck - The touch control surface companion app for FLEX Radios
Hello All, I want to introduce ControlDeck — The touch control surface companion app for FLEX-6000 and 8000 series (and maybe Aurora? Haven't been able to test)
Available now on the AppStore. Android coming soon.
https://apps.apple.com/us/app/controldeck-sdr-hot-keys/id6762167078
https://controldeckapp.com
It runs alongside SmartSDR (or any other SDR client) on your network.
Real touch controls for everything you'd normally mouse through: VFO tune (10 Hz to 100 kHz steps), band and mode switching, filter bandwidth presets, AGC, RIT/XIT, ATU, antenna selection, RF power etc.
The killer feature is multi-step action macros. Chain a sequence of radio commands into one tap. A SPLT DX macro locks the slice, creates a new slice at 2 Hz, sets audio pan, configures a narrow filter, and arms TX on the new slice. One button. Pin it where you need it.
Both local network discovery and SmartLink for remote support. MultiFlex aware, multi-slice support.
Supported radios: FLEX-6300, 6400, 6500, 6600, 6700, 6400M, 6600M, 8400, 8600 (haven't tested Aurora yet)
Requires iOS 17+ on iPhone and iPad. Support for Android 9+ coming soon.
No tracking. No analytics. No third-party SDKs. No ads. Paid app — no in-app purchases, no subscriptions.
https://controldeckapp.com to learn more.
Tom Bowles — KE5CW
  • serialcoder
    serialcoder Member ✭✭
    Do you have control over appstore region? It’s not available in France
  • TomKE5CW
    TomKE5CW Member ✭✭
    Hopefully sometime in the near future. Working on EU approvals.
  • johnn1jm
    johnn1jm Member ✭✭✭
    Doesn't show up in my App Store.
  • Russ Ravella
    Russ Ravella Member ✭✭✭
    Hi John,
    I couldn't find it by searching in the app store but when I clicked the link from within my iPhone it gave me an option to "Open in App Store" and that brought it up.
    GL Russ KR6W
  • John K3MA
    John K3MA Member ✭✭✭
    Does it allow for a key pad button to select a Global Profile?
  • TomKE5CW
    TomKE5CW Member ✭✭
    @johnn1jm it may take up to 24 hrs for the app to show up in AppStore search. The link should work until then. Thanks for checking it out and let me know if you have any questions.
  • TomKE5CW
    TomKE5CW Member ✭✭
    @"John - K3MA" This is a great idea. I'll look into adding it in the next release.
  • John K3MA
    TU, I like many others, have Global Profiles assigned for each mode and band and use those to immediately switch our operating frequency and mode.
    It would be a great enhancement to have an old Android phone set up with your app for a one button push to move around the bands and modes.
  • TomKE5CW
    TomKE5CW Member ✭✭
    @"John - K3MA" Good to know. Android will be coming soon. Btw, ControlDeck can do what you're asking with the Macro feature where you can stack multiple actions into a single button. Agree that Global Profiles would be nice since they follow the radio and work the same across all clients.
  • Dan Trainor
    Dan Trainor Member ✭✭✭
    I don't use "Band" buttons in SmartSDR. I use Global profile selection to change bands, as most people do. This works around a long standing problem of Band/Mode coherence. So my Global Profiles are named like CW 40m, SSB 20m, AM 80m, etc, Transmit Profiles use exact same convention. So, in ControlDeck, I would need buttons for Mode/Band selection simply by selecting the Global Profile by name. So, in other words, they would be buttons to select Global Profiles that are defined. The "Band" buttons and "Mode" buttons would be removed as they are not needed or desired. Band and Mode is selected by selecting the Global Profile which is automatically linked with associated Transmit Profile. When setting up operation this way, everything is simplified, consistent and reliable.. Hope that makes sense. I will put in an enhancement request soon, if not already supported. Dan WA1QZX.
  • TomKE5CW
    TomKE5CW Member ✭✭
    @serialcoder Apple tells me it’s available in the EU now. Give it a try and let me know! Thanks again.
  • johnn1jm
    johnn1jm Member ✭✭✭
    edited May 24
    How about a trial version?
  • TomKE5CW
    TomKE5CW Member ✭✭
    @johnn1jm I'd be glad to add you as a tester so you can try it free via TestFlight — all I ask is that you take a look and let me know whats missing. Email me at support@controldeckapp.com if you're interested!
  • Joe Herreweyers
    Joe Herreweyers Member ✭✭
    Hi Tom,
    A feature i would be most curious about is a memory system that stores by the slice. This would allow and maintain Dax channels on specific channels, which are subject to change otherwise. I can see using an older I pad for this on the desktop. If you are looking for a few other testers, please count me in.
    Thank you for your work,
    Joe N9EMC
  • TomKE5CW
    TomKE5CW Member ✭✭
    @"Joe Herreweyers" I believe global profiles would solve your challenge with DAX memories. I'm researching adding global profile support to the next release.
    Shoot me an email at support@controldeckapp.com and I'll add you to the testers list. Appreciate it.
  • TomKE5CW
    TomKE5CW Member ✭✭
    @John K3MA @Dan Trainor @Joe Herreweyers Global Profile hotkey buttons are now available in the public release (v1.1). This is directly from your feedback — thank you!
  • Dan Trainor
    Tom, Awesome on addition of Global Profile hotkey buttons! Thank you thank you! Dan WA1QZX
  • John K3MA
    TU, I will get it as soon as the Android version is released.
