Channel disabled
Hi,
Any suggestions?
Steve
N3UYI
    Hi Steve, in the control panel, click DAX button so that it is highlighted in blue.
    Now the TX Stream should show On in blue.
  • smprior52
    smprior52 Member ✭✭
    Len,
    I sent a ticket into the help desk. It turns out that not all previous versions ofSmart SDR cat and dax where not deleted.
    Did a search for any instances of smartSdr - Need less to say there were quite a few, much to my surprise.
    Still have 10 or so files that I can not delete. Issues as follows:
    This not a Flex issue but I tried to make the security changes without any sucess. Maybe some windows guru could help here.
    Do you have any suggestions?
    Steve
    N3UYI
  • Erik Carling EI4KF
    Use Wise Force Deleter to unlock, reset permissions and delete the files.
    https://www.wisecleaner.com/wise-force-deleter-user-guide.html
    It is safe and straightforward. Simply drag the file to the WFD UI and bingo.
