Aurora/Maestro Power setting/Power meter
df4wx
df4wx Member ✭✭
Hi,
while power setting with SmartSDR works without issues, I can set the output power with Maestro (C) to not more than 100W. But, if I set to 100W, the power meter shows an output of 500W. When I set the power to 10W, the meter shows about 50W.
It seems, the power button is wrong by the factor 5.
This is a little bit annoying, especially in bands with a power limit. E.g. the 60m-band is limited to 15W here in Europe. So I have to set the output power to 3W to be legal.
Is this a bug or a feature? Did others have similar observations?
73 Micha DF4WX
  • Arnold Goldman
    Arnold Goldman Member ✭✭
    yes i thought the same thing; aurora uses % NOT WATTS like the 8600M!!
  • Geoff AB6BT
    Geoff AB6BT Member ✭✭✭
    I believe they are both in percentage. Nowhere is there a statement that the numbers on the scale refer to Watts.
  • df4wx
    df4wx Member ✭✭
    edited May 15
    I see… Thank you. That explains everything. I mostly use the Maestro, which does not display the percent sign in the TX Band Settings, as the SmartSDR software does.
    73 Micha
  • Geoff AB6BT
    This is from the User Guide:
    RF Power slider control: Moving the slider control to the right increases the RF power
    output. A value of 0 will not produce any RF output. The scale, from 0 – 100 approximates
    RF output wattage.
    But the scale in marked in neither Watts or Percent.
  • df4wx
    df4wx Member ✭✭
    Hi Geoff,
    you are right. It seems, the description depends on the hardware and it's age. Both my Maestro manual and the 6400-manual state "Sets the output power for typical transmissions." For the Aurora, I do not have a manual. It seems, the only document is the Quick Start Guide.
    I think, we can both agree, that percentage of max power and power in Watt are identical on a 100W-transceiver. With the appearance of the Aurora series the company had to make a decision. From my point of view this was the wrong decision, but I can live with it. It is easy to calculate with a factor of 5. Let's hope, the next generation isn't a 783W-Transceiver with a weird factor of 7.83 ;-)
    73 Micha DF4WX
  • Arnold Goldman
    u can use the 8600 manual but as o said i thought my 520m wasnt working at 100 !!
