Interlock issue with 8600 TGXL and Antenna Genius
With the tuner genius powered and in line, I am receiving an Interlock error when hitting the tune or mox on the 8600. If i place the TGXL in standby the issue is not present. I have reset memory on both devies and the problem persists. TX delay is set to 40ms in the 8600 setup.
I have connected my 6700 and see the same issue
Any insights to this issue are welcome.
Thank you,
Joe N9EMC
what version software on radio, tuner, and if you have AG?
Hi David, thank you for responding. Both radios had the issue - 8600 and a 6700. I do have the TGXL and AG. This morning, I did a reboot on my 16 network switch. The problem disappeared once the switch came back on line. Kind of a odd and specific glitch as everything else worked as it should. But there you have it.
Thank you again for jumping in,
Joe
