Dual Mechanical Lightning Disconnect
I was recently at a Hamfest and saw a new product that physically separates the coax cables going into and out of a Flex transceiver. I have seen other "protector" products that use relays with minimal separation between contacts. They don't offer the isolation that this one does. The alignment of the mechanical movement was very precise.
Here is the weblink and video:
Bill, NE1B
This is the one I use.
You will notice that the case is plastic. Also when the cables pull apart, the grounds are seperated. For proper installation, you need 2 different ground straps connected to the same grounding point.
When I talked to the author of this device last summer in Huntsville, he had had built over 300 of them and had first hand knowledge of several direct strike saves.
This is very inexpensive insurance.
Mike va3mw
I built this. Disconnect with 8 N connectors and one rotator connector. Provides 7" air gap. Designed and built the controller, wrote the firmware, and a server app running on a RPi that provides a web page for remote operation and real time streaming switch position updates.
What protection does a gap of a few inches afford if lightning has taversed thousands of feet already?
I must be missing something.
Thanks…
Geoff wrote:
“What protection does a gap of a few inches afford if lightning has taversed thousands of feet already? “
I saw a design idea that included a metal plate that moved into the space between the connectors automatically as they separated. The plate was grounded. The plate is intended to intercept any arcs and ground them to prevent any surges from getting to the coax going into the station.Seems like this would potentially address the concern……thoughts?
Al / NN4ZZ0
- 393 Community Topics
- 669 The Flea Market
- 174 SmartSDR+
- 451 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 73 Aurora
- 981 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 311 Shack Infrastructure
- 217 Networking
- 834 Peripherals & Station Integration
- 146 Amateur Radio Interests
