Does Slice Master work with SmartSDR 4.2.18?
After removing all earlier versions of SmartSDR (including drivers) and installing v4.2.18, Slice Master 11.g isn't working correctly. WSJT works fine if I launch is directly, but hangs when I try to launch it through Slice Master, Slice Master just hangs...
Any ideas?
  • Bob Segrest
    Bob Segrest Member
    edited May 10
    I completely purged Slice Master from my system, including Firewall rules, app settings folder and a pass through the registry editor. Then I downloaded a fresh copy of the Slice Master distribution zip file and unzipped it into a new folder.
    Slice Master is starting without any apparent errors, but when it tries to launch WSJT warnings appear in the SM status bar.
    WARNING: DAXIQ channel is not enabled in DAX Control Panel. daxiq=1 slice='A'
    This is really odd... When I launch WSJT directly, it connects to DAXIQ-A and the SmartSDR DAX IQ stream shifts from blue to green and indicates Streaming.
    What am I missing?
