Aurora 520 relays with ATU
The Aurora is a lot more SWR sensitive than the 8600. I knew that going in… It reads higher SWR on the lower band edges for my 20m and 40m beams.
When I engage the ATU, even after finding a solution, I hear relays clicking like crazy when I transmit CW. No relays without ATU but power folds back a bit. Engage ATU, loud relays.
Is this normal? Never ran the ATU with the 8600.
Thanks, and 73!
-Brian n8wrl
It sounds like something in your antenna system is more sensitive to higher power.
So, when you tune it is at a much lower power, but when you go to full power, the higher power might be causing different RF currents, or heat causing chokes to change values. This is always why you didn't see it at 100 watts and now see it at 500 watts.
Given on what you said above, these are my first thoughts.
Can you describe your antenna system? EFHW and if so, do you have the feedline choked at the radio or do you have a counterpoise at the feedpoint? Just so rough ideas.
Let us know.
I'm running the 520M I found that the aurora relays are much louder too but they do find a match quicker than my 8600M on the same antennas; have not run CW for a long time so can't answer that but I was an idiot re wattage when i first turned on the 520M reading 100% and NOT 100 watts like the 8600M; have NOT tried the tgxl with the 520M; good luck
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 70 Aurora
- 980 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 310 Shack Infrastructure
- 217 Networking
- 832 Peripherals & Station Integration
- 145 Amateur Radio Interests
