TeensyMaestro
1181920212224»
    Hi Kuno, yes, the screen should clear first. This is starting to sound like the Teensy 4.1 board.
    I will look to see if I have another display so that I can recreate your test setup today. I will let you know what I discover.
    Hi Kuno, I found a display (I'm glad I bought a spare!) and it works with just the following connected:
    VCC to 5V
    GND to G
    CS to pin 10
    RESET to pin 8
    DC/RS to pin 9
    SDI(MOSI) to pin 11
    SCK to pin 13
    LED to 3V
    SDO(MISO) to pin 12
    If this is how you are connected, then I suspect a problem with the Teensy 4.1 board. Here is mine with only these connections.
    You might try re-loading the HW2 version (V002.003B4) from my post above, just in case there was a problem with the firmware load.
    Also, do you have SmartSDR running when you boot up the TeensyMaestro? If not, try it with SmartSDR already running.
    If none of this helps, then there is most likely a problem with your Teensy 4.1 board.
  • Kuno
    Kuno Member ✭✭
    Len,
    it looks like I have to get another Teensy. I also tried the latest Beta version and wired the same way you did, but without any change. Many thanks for your patience, it will take a while till I get the new Teensy.
    vy 73 de DF1SD, Kuno
    Hi Kuno, sorry that you had so much trouble. Hopefully a new Teensy board will be all you need.
    TeensyMaestro V2.003 is now available on GitHub:
    https://github.com/KD0RC/Teensy-Maestro-for-Flex-6000-radios/releases/tag/V2.003
    Be sure to select the correct HW version for your build. HW1 is for point-to point wired units using the original KD0RC BOM. HW2 is for those using Simon, NV0E's PC board set or point to point wiring using his BOM.
    *****************************V 2.003 ****************************
    Fixed problem with more than 2 slices open at once.
    Fixed library to allow frequencies over 1,000 MHz to show correctly (thanks to Neil, G7UFO for pointing this out!).
    Fixed issue with S Meter readings of 60 dB over S9 and up.
    Fixed occasional keyer lock-up condition when in C (cootie-key) mode.
    Fixed library to use max panadapters and max slices from discovery packet instead of hard-coding them to 2.
    Changed so that SDC doesn't cancel the screen saver when it automatically adjusts AGC-T.
    Added ability to select any two slices to be displayed.  A and D are the default.  If the requested slices aren't open, it uses the lowest named open slices.  Default can be set on the SD card.
    Added ability to display s-meters C - H (2 - 7).
    Slice selection defaults to slices A and D. The default can be changed in the MMConfig.ini file. There is a new menu, Slice Menu, that allows changing which slice is shown on the left side and which is shown on the right.
    A and D are the default values to make Diversity operation easier. On a 4 slice radio, A opens first, and if not in use, D opens when DIV is selected. If DIV is off, then the lowest named open slice is shown. So if you have A and B open, you will see them both. Now engage DIV, and it will open as D. Since D is one of the specified slices, it now takes precedence over B. Shut of DIV, and B reappears. 6700 owners will want to set A and H as the defaults.
    This release mostly benefits Flex owners who have rigs with more than 2 slices (6600, 6700, 8600, AU520). I have tested this with a 6400 and an 8600, but not any of the other rigs. If anyone is using a TeensyMaestro with an Aurora, I would love to hear how it is working.
    If you are building a TeensyMaestro, post your progress here - it is interesting to see what others are doing with the project.
  • dl1mc
    dl1mc Member
    Hi Len,
    I just finished building the TeensyMaestro using the kit Neil G7UFO provides. His kit is well made and I am glad I went with it. When I saw the kit on his website, I thought I need to try it, even though I do not have any experience with soldering electronic components. The maximum I did is soldering wires. I tested a digital clock kit I purchased as a way to check if I could manage. That kit has similar components to the TeensyMaestro - and it worked. Long story short - you designed a PCB that is manageable even for someone with very little experience. So, thanks.
    Here at the club in Essen, Germany, where our clubstation has a 6700, folks were quite impressed with the TeensyMaestro. At this stage, I am trying to work it remotely from home. We use SoftEther and zerotier. I have not been able to get it working, though. You mentioned that you setup a bridge connection. I would appreciate if you could share how you got the TeensyMaestro find the Flex that way.
    vy73 Michael DL1MC
    Hi Michael, thanks for your thoughts. One little correction - Simon, NV0E designed the beautiful boards and front panels. He did a great job, and I think a lot of people have been able to build one who would not want to tackle the point-to-point version that I originally created.
    My method for using SoftEther was to have a computer at the radio site running SoftEther Server. At the operator site, I have a computer running SoftEther Client with the Ethernet port bridged to the server. I plug the TeensyMaestro into the computer at the operator site and connect to the Internet using the computer's WiFi. The term used by SoftEther is "Cascade" to connect the LAN at the radio site to the equipment at the operator site.
    I have SmartSDR running on the operator computer and connected to the radio using SmartLink.
    By the way, the blue thing at the bottom of the diagram is paddles, not a giant line plug! Use the CW Menu in the TeensyMaestro to set Keyer Output to ETHERNET if you want to use paddles or a straight key to send CW. I also find that I need a fairly high setting of CW Delay (200 - 350), depending on the quality of the Internet link. Too short of a delay causes choppiness in the CW keying.
    Let me know if this helps.
  • dl1mc
    dl1mc Member
    Thanks for the diagram. I got it working in the end and quite pleased so far. In parallel, I would like to test it with Zerotier as well. Most of the info I found was about setting up the remote site. There was one post about integrating a Maestro but that config did not work for me. Do you happen to know other Hams who made it work?
    Hi Michael, I think that ZeroTier has some issue (UDP, perhaps?).
    The Maestro is capable of using SmartLink, so no VPN is required.
  • Kuno
    Kuno Member ✭✭
    Hi Len,
    I replaced the Teensy in the meantime. Unfortunately, there is a slight improvement only. Now all the slice A information is being displayed. When I change mode, frequency or anything else the display is not updated. If I touch the display the screen returns the previous one which displays the network information and it is stuck on this screen.
    Additionally, when the TeensyMaestro is connected to my Flex, SSDR does respond very slowly when changing bands or frequency. To fix this problem it is not enough to remove the TeensyMaestro and restart SSDR, I also have to reboot the Flex.
    Any idea?
    Hi Kuno, it sounds like a possible network issue. Are the radio, computer running SmartSDR, and the TeensyMaestro all plugged into the same network switch?
  • Kuno
    Kuno Member ✭✭
    Yes, everything is on the same network switch.
    Hi Kuno, try the Teensy board unplugged from the PC board and see if you still get the slowdown. It sounds like there is a stuck switch or encoder or something on the PC board.
  • Kuno
    Kuno Member ✭✭
    Len,
    you are right, the problem must be on the board. It is working after I removed the display from the board. That means, right now only the display and the Teensy are connected. Now I have to find out why it is not working as soon as the display is soldered to the board. I will do some more testing tomorrow.
    vy 73 de DF1sD, Kuno
  • Kuno
    Kuno Member ✭✭
    Len,
    I just resoldered the display on the board. The Teensy board is unplugged and directly connected to the display and the problem is back again. I also checked all the buttons and switches. I even replaced the three chips without any success. Looks like it is time for the trash can.
    Hi Kuno, I wonder if you got a bad board. If you try a new board, test it as you add each control.
    I am at a loss as to whatever else it might be.
  • Geoff AB6BT
    Geoff AB6BT Member ✭✭✭
    Solder bridge?
  • Kuno
    Kuno Member ✭✭
    Hi Len,
    the TeensyMaestro is driving me crazy. Now I have a new PCB and a new Teensy. I soldered the display, the Teensy, U4 all the components underneath the display, only. No buttons, no switches and no encoders connected. Still getting the same problems as before. I see the slice A and B settings, but the display is not updated when I change frequency or anything else. When I touch the display it will return to the network information and stay there, I have to turn the power off and on to restart the TeensyMaestro. When changing bands in SSDR the 8600 responds very slow and I have to reboot the Flex.
    In the meantime I believe that there must be another problem. I changed the port on the network switch and replaced the LAN cable, but no change. Are there any network or transceiver settings which prevents TeensyMaestro from working?
    Hi Kuno, I am sorry to hear that you are still having these problems. I don't know of any particular network settings that would cause these issues.
    Do you have the ability to connect just the switch, radio and TeensyMaestro? Then, if possible, try just the router, radio and TeensyMaestro.
    Another thought is to see if you can borrow a known good switch.
    I sent you TeensyMaestro V2.004 in a private message, just in case that helps (I doubt it will have any effect, but is worth a try).
  • Kuno
    Kuno Member ✭✭
    Len,
    V2.004 does not display the slices. It is stuck with the network information screen. Went back to .003.
    I'm using a Netgear GS108 switch. Currently all 8 ports are in use and I don't have any problems with the other devices. That makes me believe that the switch is not the culprit. I will try to get another 1GB switch, just for the Flex, SSDR and the TeensyMaestro.
    edited May 5
    TeensyMaestro V2.004 is now available on GitHub:
    https://github.com/KD0RC/Teensy-Maestro-for-Flex-6000-radios/releases/tag/V2.004
    Be sure to select the correct HW version for your build. HW1 is for point-to point wired units using the original KD0RC BOM. HW2 is for those using Simon, NV0E's PC board set for point to point wiring using his BOM.
    *****************************V 2.004 * ***************************2
    Fixed issue where Ethernet keying did not follow a client change when in MultiFlex.
    Fixed issue where only slices A and B use acceleration.
    Added mic selection profiles for FM.
    Reorganized encoder routines into a new tab (Read_Encoders).
    Reorganized non-keyer ISRs into a new tab (ISR).
    I can't believe that I didn't notice this before… I had the old two slice limit in the acceleration routine, so slices A and B moved correctly but any other slices in use did not accelerate at all. Hopefully, this is the last of this kind of bug. Thanks to Graham, G4FNL for finding this bug and pointing it out to me! Thanks also to Peter, G4BVH for all his help in working with Graham. Sorry to have put you guys through all that troubleshooting when it was my error all along.
  • g4ivv
    g4ivv Member ✭✭
    Hi Len,
    I've tried 2.004 on my rev 2 and something isn't the same about the VFO encoders. With 2.004, if I turn the encoder slowly it doesn't respond, I have to turn it quite quickly to start tuning. I reverted to 2.003 and its working nicely, then back to 2.004 and the same issue not responding to slow turning.
    Are there any config file changes related to VFO encoders between 2.003 and 2.004?
    Thanks & 73,
    Jonathan
    Hi Jonathan, Yes, I see what you mean. I reset a value in my quest to find the error, and I think I left it in the code. I will see if I can get that fixed today.
    Hi Jonathan, give this beta version a try:
    I left some diagnostic code in the previous version trying to get to the root cause of the acceleration problem. Hopefully I haven't upset anything else…
  • g4ivv
    g4ivv Member ✭✭
    Hi Len,
    Wow, that was quick! Yes 2.005 beta is working FB, feels great. I did also check with 4 slices and whichever ones I select to control from the menu the VFO encoders work great.
    Jonathan
    Thanks Jonathan, I will release 2.005 to GitHub a little later today.
    TeensyMaestro V2.005 is now available on GitHub:
    https://github.com/KD0RC/Teensy-Maestro-for-Flex-6000-radios/releases/tag/V2.005
    Be sure to select the correct HW version for your build. HW1 is for point-to-point wired units using the original KD0RC BOM. HW2 is for those using Simon, NV0E's PC board set or point-to-point wiring using his BOM.
    *****************************V 2.005 * ***************************
    Fixed slow startup of tuning encoders.
    Fixed config issue with short and long press options.
    Fixed config issue with slice selection.
    Fixed config issue with VFO Tracking option.
    Cleaned up Ethernet Keying code.
    Cleaned up last of the MAX_SLICE vs fRig.nMaxSlice code.
    Thanks to Simon, NV0E for finding a few annoying bugs! If you loaded the beta version of 2.005 (above), I would suggest moving up to the released version to squash the aforementioned bugs.
