SSDR v4.2.18 strange install?
I uninstalled all prior versions of SSDR and manually removed the empty "Flex Radio Systems" folder. V4.2.18 install did not create a new "Program Files\Flex Radio Systems" Folder in Windows 11 Pro 64-bit ; instead, it created a "Program Files\SmartSDR v4.2.18 folder". I uninstalled v4.2.18, created a "Program Files\Flex Radio System" folder, and reinstalled v4.2.18, but it ignored the new folder and installed it again "Program Files\SmartSDR v4.2.18 folder. Also, there is no Flex VSP driver shown. Is this abnormal?
Tim got back to me to tell me all is ok. I read instructions but obviously missed this point.
Hope Flex VSP driver gets installed eventually somewhere in the process, as it's no-where to be found as a separate file on my PC.0 -
It is there if you look in Windows/system32
Yes, found it… thanks Erik! I was just used to seeing it as a separate entry in the Flex Radio Systems folder, which no longer exists with the new version install.
