Is anyone having better luck with ESC with v4.2.18?
Diversity (DIV) seems to be working well in v4.2.18, but I still can't get any noise nulling in ESC. Had same issue with v4.1. I'm using a 5 el yagi on ANT1 and a low wire antenna (for local noise) on ANT2, both on 6m. Noise levels are close to the same on both antennas. Hoping to find a null in noise at about 180 deg phase but no null found at any phase angle. Any tips or comments welcome!
    Answer ✓
    Hi Keith, this feature was not working when released in V4, and is still not working. Probably best to submit a help desk ticket to be sure that Flex is tracking it.
  • Keith - KE4TH
    Keith - KE4TH Member ✭✭
    Thanks Len. That saves me some time! I do have a help desk ticket in.
  • PhilM
    PhilM Member ✭✭
    It doesnt work for me either in fact it never worked as it should. In CW mode if you activate diversity reception it never comes back from xmit and requiring SMARTSDR to be recycled in order to receive anything again. Apparently there is some kind of internal timer, and if it is exceeded, an error occurs. I hope this is resolved since diversity RX is a basic feature of Flexradio. Not to mention as a CW operator, CW functionality seems to be forgotton at times.
    What they need to do is actually address the issues list and resolve them before adding new features.
    Also they should have a regression test that tests all features so when a new release is being prepared they can ensure features aren't regressed out ( not working anymore ).
  • Russ Ravella
    Russ Ravella Member ✭✭✭
    Hi Keith and Phil,
    Keith, I posted on this a few days ago. I've never been able to get ESC to do anything either. But I finally found a couple of signals where it clearly made some difference. It was consistent and repeatable so there's that - at least it is doing something now. I bought a TimeWave ANC-4 several years ago which is specifically designed to handle the noise cancellation case and found it extremely sensitive to choice of antenna and noise types. I spent some time trying to rig up suitable noise antennas and finally ended up with two versions that I switch between. But truth be told, I rarely get noise at my QTH that it makes any difference on. Other's report cases where it makes a big difference though. Point being it's hard to assess how well ESC is working without a lot of experimenting with antennas and checking out a lot of noise sources. Note that it isn't enough for both antennas to be hearing the noise, the signal antenna needs to have significantly greater signal (to noise) than the noise antenna for it to work.
    That said, as Len states, Flex is saying they're still working on ESC. They have a delay between the two ESC channels that impacts its performance so at best, it's not working correctly yet. And there's this too:
    Phil, I'm not able to reproduce the issue you describe with either DIV or ESC here for what it's worth. But there's definitely something pretty **** up with ESC creating a howling sound in TX but I'm seeing it pop right back to RX after TX. I'd suggest starting a ticket on that ? DIV works just fine here, however. I've been using it for years.
    Flex says while they've made a lot of progress with ESC, they're still working on it so hopefully they'll nail it in the next rev !
    GL Russ KR6W
  • John KB4DU
    John KB4DU Member ✭✭✭✭
    Mike gets pretty defensive when mention regression testing. Flex also hired a testing person, but hasn't had much impact on the Ham side of the business.
  • PhilM
    PhilM Member ✭✭
    Yes I did open issues and defect numbers have been assigned to them. There are several things I think going here. In my case it had to do with CW mode and QSK and during a fairly long QSO the problem occurs, try sending CW with QSK for 5 to 10 minutes.
    It appears to me as an old programmer that they are probably in the process of rewriting SMARTSDR at the same time having to resolve the security related issues of DAX and other code. Not being able to have storage protection active as with the old DAX violates most corporate and Department of Defense requirements, that appears to be out of the way and now other things can be addressed.
    I did use DIV ESC on SSB and it did provide some tuning using the phase control and made a noticeable change. Maybe I'll try it on FT8 but who knows if it works for that.
    Phil
