FRStack set band with Stream Deck?
dlmorgan999
I just received my FLEX-8400 (super excited!). I'm playing around with FRStack (v 4.0.0.5), and I don't see any command with the Stream Deck plugin to set the band. I can do a command like this in the browser and it works fine:
http://localhost:13522/api/ActiveSlice/BAND?param=20
I also saw this in the version history, but I don't see this in the UI:
Version 3.8.16.82
Add Band change UI
Can anyone help?
Version 3.8.16.82
Add Band change UI
Can anyone help?
I must confess I am missing something in your question. Any command you can action via a browser, you can add to a button in SD.
So I presume there is another issue. Can you elaborate?
Thanks for the response. I thought for sure I had tried that, but I must have done something different, because it's working now.0
I take it this combo is still working well with the latest SSDR release version?
Yes, it is independent of SSDR versions.
- 691 The Flea Market
- 197 SmartSDR+
- 462 SmartSDR for Mac
- 113 Aurora
- 978 Genius Products
- 136 Antenna Genius
- 323 Shack Infrastructure
- 228 Networking
