CW setup config ? 6600 100FT away on same LAN
Whats the right way to run CW from the PC desk using a paddle key. I almost bought a Winkeyer thinking that would have the PC run a clean CW on the 6600 on the same LAN but placed outside in a garage. (that ended the PGXL fan noise problem too!)
After reading the Winkeyer posts here I see thats not the right solution. I have HRD with DM-780, so will that let me use the paddles?
I sure dont want to be on a keyboard to send CW.
