CW setup config ? 6600 100FT away on same LAN
Raul Pla
Whats the right way to run CW from the PC desk using a paddle key. I almost bought a Winkeyer thinking that would have the PC run a clean CW on the 6600 on the same LAN but placed outside in a garage. (that ended the PGXL fan noise problem too!)
After reading the Winkeyer posts here I see thats not the right solution. I have HRD with DM-780, so will that let me use the paddles?
I sure dont want to be on a keyboard to send CW.
Morconi is the solution.
https://www.morconi.com
Thank you. I just have to read up and learn. Looks like it connects directly to an ethernet LAN, next to the radio. In any case, I didn't read up on it yet so Im thinking blindly.
